주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Pavilion 15-cd040wm RAM Replacement
필요한 것
    1. HP Pavilion 15-cd040wm RAM Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-cd040wm RAM Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: 1 단계, 이미지 2개 중 2개
      • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
      • If you have trouble gripping a tab, use a spudger to wedge it loose.
      댓글 쓰기
    2. HP Pavilion 15-cd040wm RAM Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 15-cd040wm RAM Replacement: 2 단계, 이미지 2개 중 2개
      • 3x 10mm Phillips scews
      • 2x 5mm Phillips screws
      • 6x 6mm Phillips screws
      • Remove all screws using a size Phillips #0 screwdriver.
      댓글 쓰기
    3. HP Pavilion 15-cd040wm RAM Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion 15-cd040wm RAM Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion 15-cd040wm RAM Replacement: 3 단계, 이미지 3개 중 3개
      • Using the iFixit opening tool, carefully pry along the sides of the back cover.
      • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
      • After everything is unclipped, you can safely remove the back cover from the rest of the device.
      댓글 쓰기
    1. HP Pavilion 15-cd040wm RAM Replacement, Battery: 4 단계, 이미지 2개 중 1개 HP Pavilion 15-cd040wm RAM Replacement, Battery: 4 단계, 이미지 2개 중 2개
      • 2x 5mm Philips screws
      • 2x 3mm Philips screws
      댓글 쓰기
    2. HP Pavilion 15-cd040wm RAM Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion 15-cd040wm RAM Replacement: 5 단계, 이미지 2개 중 2개
      • Gently pull up on the battery and tilt it away from the rest of the laptop chassis.
      • Pull out the battery at an angle and lift it out of the laptop.
      댓글 쓰기
    1. HP Pavilion 15-cd040wm RAM Replacement, RAM: 6 단계, 이미지 3개 중 1개 HP Pavilion 15-cd040wm RAM Replacement, RAM: 6 단계, 이미지 3개 중 2개 HP Pavilion 15-cd040wm RAM Replacement, RAM: 6 단계, 이미지 3개 중 3개
      • Pull the two tabs at the short ends of the RAM module with your fingers to release it, then pull the RAM module out of the slot.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Brian Cornet
회원 가입일: 10/21/19
319 평판
안내서 3개를 작성함
UMass Dartmouth, Team S1-G1, Botvin Fall 2019 UMass Dartmouth, Team S1-G1, Botvin Fall 2019 회원
UMASSD-BOTVIN-F19S1G1
4 회원들
안내서 71개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 40
전체 시간: 1,387
