주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Pavilion 15-cd040wm Screen Replacement
필요한 것
  1. HP Pavilion 15-cd040wm Screen Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-cd040wm Screen Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: 1 단계, 이미지 2개 중 2개
    • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
    • If you have trouble gripping a tab, use a spudger to wedge it loose.
    댓글 쓰기
  2. HP Pavilion 15-cd040wm Screen Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 15-cd040wm Screen Replacement: 2 단계, 이미지 2개 중 2개
    • 3x 10mm Phillips scews
    • 2x 5mm Phillips screws
    • 6x 6mm Phillips screws
    • Remove all screws using a size Phillips #0 screwdriver.
    댓글 쓰기
  3. HP Pavilion 15-cd040wm Screen Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion 15-cd040wm Screen Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion 15-cd040wm Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Using the iFixit opening tool, carefully pry along the sides of the back cover.
    • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
    • After everything is unclipped, you can safely remove the back cover from the rest of the device.
    댓글 쓰기
  4. HP Pavilion 15-cd040wm Screen Replacement, Battery: 4 단계, 이미지 2개 중 1개 HP Pavilion 15-cd040wm Screen Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • 2x 5mm Philips screws
    • 2x 3mm Philips screws
    댓글 쓰기
  5. HP Pavilion 15-cd040wm Screen Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion 15-cd040wm Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Gently pull up on the battery and tilt it away from the rest of the laptop chassis.
    • Pull out the battery at an angle and lift it out of the laptop.
    댓글 쓰기
  6. HP Pavilion 15-cd040wm Screen Replacement, Screen: 6 단계, 이미지 3개 중 1개 HP Pavilion 15-cd040wm Screen Replacement, Screen: 6 단계, 이미지 3개 중 2개 HP Pavilion 15-cd040wm Screen Replacement, Screen: 6 단계, 이미지 3개 중 3개
    • Remove the four 6.0 mm screws from the hinges using a size Phillips #0 screwdriver.
    • Use the iFixit opening tool to lift both of the hinges.
    댓글 쓰기
  7. HP Pavilion 15-cd040wm Screen Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion 15-cd040wm Screen Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion 15-cd040wm Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Using the spudger or opening tool, remove the ribbon that connects to the screen.
    • Gently pull the ribbon out of the port after using the spudger to lift the supporter up.
    • Carefully remove the two antenna wires that connect to the screen as well. Do this by gently pulling them free from their connectors at the wifi card.
    댓글 쓰기
  8. HP Pavilion 15-cd040wm Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Once these steps are completed, you may lift the display assembly free from the rest of the device.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Zachary Simao
회원 가입일: 03/08/19
423 평판
안내서 2개를 작성함
UMass Dartmouth, Team S1-G1, Botvin Fall 2019 UMass Dartmouth, Team S1-G1, Botvin Fall 2019 회원
UMASSD-BOTVIN-F19S1G1
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 24
전체 시간: 1,128
