주요 콘텐츠로 건너뛰기
HP Pavilion 15-p043cl Repair Optical Drive Replacement
Teague Mendez
Teague Mendez3 다른 기여자
최종 수정일 January 2, 2024
5 - 10 분
쉬움
If your laptop is having disc-reading errors or if the sound or video is degraded when using the CD Or DVD disc, use this guide if you need to replace your optical drive. For this guide you will need a #1 Phillips screwdriver. We will be unscrewing a screw size of 8 mm. This replacement is simple and doesn't require extensive knowledge.
필요한 것
도구
  1. HP Pavilion 15-p043cl Repair Optical Drive Replacement, Optical Drive: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-p043cl Repair Optical Drive Replacement, Optical Drive: 1 단계, 이미지 2개 중 2개
    • Flip over the laptop so that the screws on the bottom are exposed.
  2. HP Pavilion 15-p043cl Repair Optical Drive Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 15-p043cl Repair Optical Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Use a #1 Phillips screwdriver to remove the single 8 mm screw that secures the optical drive.
    • There is a CD/DVD symbol on the case that helps identify the correct screw.
  3. HP Pavilion 15-p043cl Repair Optical Drive Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion 15-p043cl Repair Optical Drive Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion 15-p043cl Repair Optical Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Use your fingers or a wedge to pull out the Optical Drive from it's slot.
    • If the faceplate of the drive is pulled off it can be reattached.
결론
작성자
3다른 기여자 명과 함께
Teague Mendez
회원 가입일: 10/01/23
692 평판
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 17
전체 시간: 101
