주요 콘텐츠로 건너뛰기
HP Pavilion 15-p043cl Repair RAM Replacement
Teague Mendez
Teague Mendez3 다른 기여자
최종 수정일 January 2, 2024
15 - 20 분
조정
더 나은 소개글
필요한 것
도구
  1. HP Pavilion 15-p043cl Repair RAM Replacement, Optical Drive: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-p043cl Repair RAM Replacement, Optical Drive: 1 단계, 이미지 2개 중 2개
    • Flip over the laptop so that the screws on the bottom are exposed.
  2. HP Pavilion 15-p043cl Repair RAM Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 15-p043cl Repair RAM Replacement: 2 단계, 이미지 2개 중 2개
    • Use a #1 Phillips screwdriver to remove the single 8 mm screw that secures the optical drive.
    • There is a CD/DVD symbol on the case that helps identify the correct screw.
  3. HP Pavilion 15-p043cl Repair RAM Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion 15-p043cl Repair RAM Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion 15-p043cl Repair RAM Replacement: 3 단계, 이미지 3개 중 3개
    • Use your fingers or a wedge to pull out the Optical Drive from it's slot.
    • If the faceplate of the drive is pulled off it can be reattached.
  4. HP Pavilion 15-p043cl Repair RAM Replacement, RAM: 4 단계, 이미지 3개 중 1개 HP Pavilion 15-p043cl Repair RAM Replacement, RAM: 4 단계, 이미지 3개 중 2개 HP Pavilion 15-p043cl Repair RAM Replacement, RAM: 4 단계, 이미지 3개 중 3개
    • Use a #1 Phillips-head screwdriver to remove the ten additional 8 mm bottom case screws.
  5. HP Pavilion 15-p043cl Repair RAM Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion 15-p043cl Repair RAM Replacement: 5 단계, 이미지 2개 중 2개
    • Pull out the battery by positioning the switch with the lock symbol on unlock and pushing the switch with the battery towards the center of the laptop
  6. HP Pavilion 15-p043cl Repair RAM Replacement: 6 단계, 이미지 3개 중 1개 HP Pavilion 15-p043cl Repair RAM Replacement: 6 단계, 이미지 3개 중 2개 HP Pavilion 15-p043cl Repair RAM Replacement: 6 단계, 이미지 3개 중 3개
    • Flip over the laptop so the HP symbol is facing up.
    • Open the lid of the laptop.
    • Using the spudger, pry between the case and keyboard/mousepad area. Work all the way around the case.
  7. HP Pavilion 15-p043cl Repair RAM Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion 15-p043cl Repair RAM Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion 15-p043cl Repair RAM Replacement: 7 단계, 이미지 3개 중 3개
    • Carefully remove the keyboard area.
    • Make sure to unplug the 3 ribbon cables connecting the keyboard. mousepad, and power button to the motherboard.
  8. HP Pavilion 15-p043cl Repair RAM Replacement: 8 단계, 이미지 2개 중 1개 HP Pavilion 15-p043cl Repair RAM Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the remaining ribbon cables.
    • Remove the connection to the HDMI port.
  9. HP Pavilion 15-p043cl Repair RAM Replacement: 9 단계, 이미지 3개 중 1개 HP Pavilion 15-p043cl Repair RAM Replacement: 9 단계, 이미지 3개 중 2개 HP Pavilion 15-p043cl Repair RAM Replacement: 9 단계, 이미지 3개 중 3개
    • Remove the remaining motherboard screws.
    • Gently lift the motherboard up, towards the screen of the laptop. Remove the remaining display connector.
  10. HP Pavilion 15-p043cl Repair RAM Replacement: 10 단계, 이미지 2개 중 1개 HP Pavilion 15-p043cl Repair RAM Replacement: 10 단계, 이미지 2개 중 2개
    • Locate the RAM.
    • Pull the metal tabs to the side while pulling the RAM module out and slightly up.
결론
작성자
3다른 기여자 명과 함께
Teague Mendez
회원 가입일: 10/01/23
692 평판
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 16
전체 시간: 133
