HP Pavilion 17-ak008cy Hard Drive Replacement
In this guide you will be replacing the Hard Drive in the need of more storage. Use cation when taking off the back plate, as well as when disconnecting and reconnecting wires and the hard drive. Too much force will cause damage to the parts.
****Disclaimer: At the time of guide creation, the hard drive was not included in the device. The images in this guide will not*** show the hard drive in the device.
Remove eleven screws from the back panel.
Remove the optical drive from the side.
Remove the back panel from the device.
Carefully detach the connector above the hard drive.
Remove the hard drive from the device.
다른 3명이 해당 안내서를 완성하였습니다.
