주요 콘텐츠로 건너뛰기
HP Pavilion 17-e117dx Optical Drive Replacement
Marcel Amazan
Marcel Amazan다른 한 명의 기여자
최종 수정일 July 14, 2019
5 - 7 분
조정
The optical drive is most commonly known as a CD/DVD drive. Replacing the optical drive is a solution for an optical drive that isn’t functioning properly.
Before beginning this procedure, you’ll need to power off the laptop and unplug anything that is plugged into the laptop. You will also need to remove the laptop’s battery.
Also, make sure your hands are clean and dry.
필요한 것
도구
  1. HP Pavilion 17-e117dx Optical Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the laptop upside down, so that the bottom is facing up.
  2. HP Pavilion 17-e117dx Optical Drive Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 17-e117dx Optical Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the battery release latch to the left. The battery will pop up slightly.
    • Lift the battery upwards and out of the laptop.
  3. HP Pavilion 17-e117dx Optical Drive Replacement, Service Panel: 3 단계, 이미지 2개 중 1개 HP Pavilion 17-e117dx Optical Drive Replacement, Service Panel: 3 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, remove the single Phillips 3.0 x 10.5 mm screw that fastens the service panel to the laptop.
  4. HP Pavilion 17-e117dx Optical Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Slide the service panel towards you to loosen it from the laptop.
  5. HP Pavilion 17-e117dx Optical Drive Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the service panel.
  6. HP Pavilion 17-e117dx Optical Drive Replacement, Optical Drive: 6 단계, 이미지 2개 중 1개 HP Pavilion 17-e117dx Optical Drive Replacement, Optical Drive: 6 단계, 이미지 2개 중 2개
    • Remove the single Phillips PM 2.5 x 5.75 screw that secures the optical drive to the computer.
    • Use the Phillips #00 screwdriver.
  7. HP Pavilion 17-e117dx Optical Drive Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion 17-e117dx Optical Drive Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion 17-e117dx Optical Drive Replacement: 7 단계, 이미지 3개 중 3개
    • Slide the optical drive out of the computer.
결론
작성자
1다른 기여자 명과 함께
Marcel Amazan
회원 가입일: 03/24/19
576 평판
안내서 5개를 작성함
UMass Dartmouth, Team S8-G5, Bailey Spring 2019 UMass Dartmouth, Team S8-G5, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S8G5
2 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 3
전체 시간: 408
