주요 콘텐츠로 건너뛰기
HP Pavilion N3350 Screen Assembly Replacement
Emily Hatstat
Emily Hatstat3 다른 기여자
최종 수정일 May 7, 2024
20 - 30 분
조정
If the screen of your laptop is black when powered on, or cracked, it should be replaced. With the purchase of a new screen, follow these steps to replace it completely.
필요한 것
도구
더보기...
  1. HP Pavilion N3350 Screen Assembly Replacement, Screen Assembly: 1 단계, 이미지 2개 중 1개 HP Pavilion N3350 Screen Assembly Replacement, Screen Assembly: 1 단계, 이미지 2개 중 2개
    • Open your laptop. Beneath the screen, there is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights.
    • To remove this, pry it open with a spudger tool gently. It should pop out of place.
  2. HP Pavilion N3350 Screen Assembly Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion N3350 Screen Assembly Replacement: 2 단계, 이미지 2개 중 2개
    • Gently use a spudger tool or your fingers to disconnect the LCD cable from the screen.
    • This is one of three connectors that needs to be undone to disconnect the screen from the laptop.
  3. HP Pavilion N3350 Screen Assembly Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion N3350 Screen Assembly Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion N3350 Screen Assembly Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the 1 cm screw with a Phillips #1 screwdriver to allow the screen and top of the laptop to be separated from the keyboard and bottom.
    • Lift the entire top away from the bottom, and set bottom half of the laptop aside.
  4. HP Pavilion N3350 Screen Assembly Replacement: 4 단계, 이미지 3개 중 1개 HP Pavilion N3350 Screen Assembly Replacement: 4 단계, 이미지 3개 중 2개 HP Pavilion N3350 Screen Assembly Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the 6 rubber screw caps with a metal spudger.
    • After removing the 6 rubber screw caps, use a Phillips #1 screwdriver to unscrew the six 6mm screws.
  5. HP Pavilion N3350 Screen Assembly Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion N3350 Screen Assembly Replacement: 5 단계, 이미지 2개 중 2개
    • To separate the plastic cover, use a plastic opening tool to undo each plastic connecting clip between the two.
    • You can find the plastic connecting clips by sliding the plastic opening tool along the seam between the two plastic covers.
    • Remove the top plastic cover once all connections have been released.
  6. HP Pavilion N3350 Screen Assembly Replacement: 6 단계, 이미지 3개 중 1개 HP Pavilion N3350 Screen Assembly Replacement: 6 단계, 이미지 3개 중 2개 HP Pavilion N3350 Screen Assembly Replacement: 6 단계, 이미지 3개 중 3개
    • Disconnect the connectors using a plastic opening tool.
    • Once these two connectors are released, the screen should be electronically freed from the rest of the laptop.
  7. HP Pavilion N3350 Screen Assembly Replacement: 7 단계, 이미지 1개 중 1개
    • At each corner, there is a 1 centimeter silver screw connecting the screen frame to the laptop. Remove these using a Phillips #1 Screwdriver.
  8. HP Pavilion N3350 Screen Assembly Replacement: 8 단계, 이미지 3개 중 1개 HP Pavilion N3350 Screen Assembly Replacement: 8 단계, 이미지 3개 중 2개 HP Pavilion N3350 Screen Assembly Replacement: 8 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • There should be thin piece of copper 'tape' holding the LCD cable down. Remove this gently with tweezers.
    • Remove the screen from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Emily Hatstat
회원 가입일: 03/19/18
481 평판
안내서 4개를 작성함
UMass Dartmouth, Team S3-G8, Peak Spring 2018 UMass Dartmouth, Team S3-G8, Peak Spring 2018 회원
UMASSD-PEAK-S18S3G8
3 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 2
전체 시간: 212
