HP Pavilion Sleekbook 14-b013cl Battery Replacement
This guide should be used if you have experienced issues with the battery, such as the battery not holding a charge or the computer only turning on while plugged in. Make sure that the device is fully powered off before attempting to remove the battery. No tools are required for this guide.
Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
Place your new battery into the slot you just removed the old battery out of, and follow the steps in reverse order to accomplish this.
다른 한 분이 해당 안내서를 완성하였습니다.
