주요 콘텐츠로 건너뛰기
HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement
James Barlow-Jones
James Barlow-Jones3 다른 기여자
최종 수정일 May 13, 2021
15 - 25 분
조정
In this guide, you will learn how to replace your HP pavilion Sleekbook's Hard Disk Drive (HDD).
필요한 것
수리 키트
이 키트는 이 안내서를 완료하는데 필요한 모든 부품과 도구를 포함하고 있습니다.
부품
도구
더보기...
  1. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
  2. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
  3. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Carefully pull the battery away from the device.
  4. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1개 중 1개
    • Using a Phillips #0 screwdriver, unscrew all eight of the screws.
  5. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, pry up on the upper edge of the keyboard.
    • There is a wire connecting the keyboard to the motherboard. Do not pull the keyboard away until you have disconnected it.
  6. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 6 단계, 이미지 3개 중 1개 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 6 단계, 이미지 3개 중 2개 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 6 단계, 이미지 3개 중 3개
    • To disconnect the wire, pry up on the latch holding it in its socket.
  7. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 7 단계, 이미지 3개 중 3개
    • Flip the laptop back over.
    • Using a plastic or metal spudger, carefully pry the top and bottom halves of the case appart.
    • Don't push the metal spudger in too far or you might damage the laptops internal components.
    • Do not pull the halves apart yet as there are still wires attaching them together.
  8. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 8 단계, 이미지 3개 중 1개 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 8 단계, 이미지 3개 중 2개 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 8 단계, 이미지 3개 중 3개
    • Disconnect the touch pad wire by flipping the small black lever using a plastic opening tool.
  9. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 9 단계, 이미지 2개 중 1개 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 9 단계, 이미지 2개 중 2개
    • Unscrew the small circuit board underneath the power button.
    • Remove the circuit board by pulling up and away on the plastic tab.
  10. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 10 단계, 이미지 1개 중 1개
    • Pull the top half of the plastic case off of the laptop.
  11. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 11 단계, 이미지 3개 중 1개 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 11 단계, 이미지 3개 중 2개 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 11 단계, 이미지 3개 중 3개
    • Remove all seven of the screws using a Phillips #0 screwdriver and pull the plate off the motherboard.
    • There is double sided tape holding the plate down, as well as the screws. Sufficient force will be required to remove the plate.
  12. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 12 단계, 이미지 2개 중 1개 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the USB wire which runs over the top of the hard drive.
    • The wire is stuck to the hard drive with double sided tape.
    • Remove the wire by carefully pulling towards the USB connector on the left hand side of the laptop.
  13. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 13 단계, 이미지 2개 중 1개 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the four screws securing the hard drive to the motherboard.
    • Disconnect the hard drive cable by gently pulling it away from the hard drive.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
James Barlow-Jones
회원 가입일: 09/26/17
325 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 31
전체 시간: 2,224
