주요 콘텐츠로 건너뛰기
HP Pavilion Sleekbook 15-b000 Keyboard Replacement
Sam Barkley
Sam Barkley4 다른 기여자
최종 수정일 February 25, 2025
2 분
쉬움
The keyboard is one of the main components needed to interact with your laptop. This guide will show you how to replace your keyboard if you are having issues with typing on your laptop or to remove the keyboard for any further repairs to your laptop.
필요한 것
도구
  1. HP Pavilion Sleekbook 15-b000 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Unplug laptop from adapter and all other devices.
  2. HP Pavilion Sleekbook 15-b000 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Flip the laptop over with battery facing you.
  3. HP Pavilion Sleekbook 15-b000 Keyboard Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion Sleekbook 15-b000 Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. HP Pavilion Sleekbook 15-b000 Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Pull battery out.
  5. HP Pavilion Sleekbook 15-b000 Keyboard Replacement, Keyboard: 5 단계, 이미지 1개 중 1개
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. HP Pavilion Sleekbook 15-b000 Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. HP Pavilion Sleekbook 15-b000 Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  8. HP Pavilion Sleekbook 15-b000 Keyboard Replacement: 8 단계, 이미지 1개 중 1개
    • Remove keyboard wire by popping latch under blue plastic
결론
작성자
4다른 기여자 명과 함께
Sam Barkley
회원 가입일: 02/13/18
1,007 평판
안내서 8개를 작성함
USF Tampa, Team S11-G2, Cheng Spring 2018 USF Tampa, Team S11-G2, Cheng Spring 2018 회원
USFT-CHENG-S18S11G2
4 회원들
안내서 18개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 21
지난 30일: 23
전체 시간: 323
