주요 콘텐츠로 건너뛰기
HP Pavilion Sleekbook 15-b000 Motherboard Replacement
Sam Barkley
Sam Barkley2 다른 기여자
최종 수정일 February 25, 2025
40 분
조정
This guide will walk you through the step by step process to remove the mother board from your laptop. You will need to do this if you are having issues with the laptop booting or to remove the WiFi card or RAM.
필요한 것
도구
  1. HP Pavilion Sleekbook 15-b000 Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Unplug laptop from adapter and all other devices.
  2. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Flip the laptop over with battery facing you.
  3. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion Sleekbook 15-b000 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Pull battery out.
  5. HP Pavilion Sleekbook 15-b000 Motherboard Replacement, Keyboard: 5 단계, 이미지 1개 중 1개
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  8. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Remove keyboard wire by popping latch under blue plastic
  9. HP Pavilion Sleekbook 15-b000 Motherboard Replacement, Case: 9 단계, 이미지 1개 중 1개
    • Using the spudger to lift up on the white tabs
    • Pull horizontally on the blue ribbon to disconnect the cables
  10. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the five 5.5mm Phillips #1 screws from the case
  11. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Remove eight 6.5mm Phillips #1 screws from the back cover
  12. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: 12 단계, 이미지 3개 중 1개 HP Pavilion Sleekbook 15-b000 Motherboard Replacement: 12 단계, 이미지 3개 중 2개 HP Pavilion Sleekbook 15-b000 Motherboard Replacement: 12 단계, 이미지 3개 중 3개
    • Starting at a top corner, use the pry tool to split the case.
    • Slowly work around the case, pulling up gently to release the clips.
  13. HP Pavilion Sleekbook 15-b000 Motherboard Replacement, Hard Drive: 13 단계, 이미지 1개 중 1개
    • Remove the 4 x 5.5 mm screws connecting the hard drive tot he case.
  14. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: 14 단계, 이미지 1개 중 1개
    • Remove hard drive from bracket being careful of it's cable.
  15. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: 15 단계, 이미지 1개 중 1개
    • Disconnect cable from hard drive.
  16. HP Pavilion Sleekbook 15-b000 Motherboard Replacement, Motherboard: 16 단계, 이미지 2개 중 1개 HP Pavilion Sleekbook 15-b000 Motherboard Replacement, Motherboard: 16 단계, 이미지 2개 중 2개
    • Disconnect motherboard cable from left side USB and jacks
  17. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: 17 단계, 이미지 1개 중 1개
    • Remove the six 5.5mm Phillips #1 motherboard screws
    • Remove the one 3.5mm Phillips #1 screw from the WiFi chip
  18. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: 18 단계, 이미지 1개 중 1개
    • Remove motherboard.
결론
작성자
2다른 기여자 명과 함께
Sam Barkley
회원 가입일: 02/13/18
1,007 평판
안내서 8개를 작성함
USF Tampa, Team S11-G2, Cheng Spring 2018 USF Tampa, Team S11-G2, Cheng Spring 2018 회원
USFT-CHENG-S18S11G2
4 회원들
안내서 18개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 16
전체 시간: 702
