주요 콘텐츠로 건너뛰기
HP Pavilion Touchsmart 11z-e000 RAM Replacement
Daniel
Daniel4 다른 기여자
최종 수정일 June 29, 2015
10 - 15 분
조정
Memory, commonly known as RAM, is largely responsible for the speed of a computer, as it allows data to to be read and written. Improving your computers RAM may increase speed and allow your computer to run more programs simultaneously. The HP Pavilion TouchSmart 11z-e000 comes with 4gb of RAM. Typical RAM sizes range from 4gb-16gb. This laptop has one memory module slot which allows it to be upgraded to 8gb.
필요한 것
도구
  1. HP Pavilion Touchsmart 11z-e000 RAM Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
  2. HP Pavilion Touchsmart 11z-e000 RAM Replacement, RAM: 2 단계, 이미지 1개 중 1개
    • Slide a spudger under the outer plastic cover of the laptop
    • Pull off the plastic cover of the laptop.
  3. HP Pavilion Touchsmart 11z-e000 RAM Replacement: 3 단계, 이미지 1개 중 1개
    • Push both tabs outward to release the memory module
  4. HP Pavilion Touchsmart 11z-e000 RAM Replacement: 4 단계, 이미지 1개 중 1개
    • Grasp the memory module by the edge and pull gently to remove it
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Daniel
회원 가입일: 01/22/15
158 평판
안내서 1개를 작성함
Cal Poly, Team 21-22, Maness Winter 2015 Cal Poly, Team 21-22, Maness Winter 2015 회원
CPSU-MANESS-W15S21G22
4 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 13
전체 시간: 1,062
