주요 콘텐츠로 건너뛰기
HP Pavilion dv6-6117dx RAM Replacement
Joshua Holme
Joshua Holme다른 한 명의 기여자
최종 수정일 June 12, 2018
2 - 5 분
쉬움
Is your computer running slow? One cause could be an insufficient amount of RAM. By following this guide below, you can upgrade the RAM in your HP Pavilion dv6-6117dx to help give your computer a breath of fresh air.
필요한 것
도구
  • Spudger
    Spudger
  1. HP Pavilion dv6-6117dx RAM Replacement, RAM: 1 단계, 이미지 2개 중 1개 HP Pavilion dv6-6117dx RAM Replacement, RAM: 1 단계, 이미지 2개 중 2개
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx RAM Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion dv6-6117dx RAM Replacement: 2 단계, 이미지 2개 중 2개
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx RAM Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion dv6-6117dx RAM Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion dv6-6117dx RAM Replacement: 3 단계, 이미지 3개 중 3개
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx RAM Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion dv6-6117dx RAM Replacement: 4 단계, 이미지 2개 중 2개
    • Push the tabs on both sides away from each other to free the RAM, which will raise to a 45º angle.
  5. HP Pavilion dv6-6117dx RAM Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion dv6-6117dx RAM Replacement: 5 단계, 이미지 2개 중 2개
    • Always handle RAM by the edges to avoid damaging the part.
    • Remove the RAM by grabbing it by the sides and pulling out at a 45º angle.
    • When inserting the new stick of RAM, you should insert it at this same angle.
결론
작성자
1다른 기여자 명과 함께
Joshua Holme
회원 가입일: 03/19/18
765 평판
안내서 4개를 작성함
UMass Dartmouth, Team S6-G3, Bernier Spring 2018 UMass Dartmouth, Team S6-G3, Bernier Spring 2018 회원
UMASSD-BERNIER-S18S6G3
3 회원들
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 817
