주요 콘텐츠로 건너뛰기
HP Pavilion dv6-6180us Screen Replacement
michelle pulido
michelle pulido5 다른 기여자
최종 수정일 May 7, 2024
예상시간 없음
조정
If you have broken your screen or your screen has black damage to it, you may want to replace your screen.
필요한 것
도구
  1. HP Pavilion dv6-6180us Screen Replacement, Hard Drive: 1 단계, 이미지 1개 중 1개
    • Turn off and unplug the device before starting.
    • Flip your device over so the bottom panel is facing up.
  2. HP Pavilion dv6-6180us Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the lock switch to the right.
    • The panel will pop open at the top corner.
  3. HP Pavilion dv6-6180us Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to remove the back panel.
    • Some force may be required to remove the panel from the case. Use caution when prying to avoid breaking the panel or the plastic tabs securing it in place.
  4. HP Pavilion dv6-6180us Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Use the PH 1 screwdriver to remove the four 3.5 mm screws securing the hard drive.
  5. HP Pavilion dv6-6180us Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the corner bracket to remove the hard drive.
  6. HP Pavilion dv6-6180us Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Unplug the hard drive wire to detach the hard drive.
  7. HP Pavilion dv6-6180us Screen Replacement, Screen: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers, grab the top and bottom while rocking back and forth to pull rubber plug out.
    • Cover is glued into place so gently pick at the edge before removing.
  8. HP Pavilion dv6-6180us Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Unscrew two 6mm screws using PH1 screwdriver.
  9. HP Pavilion dv6-6180us Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Pry the left lower corner with fingers.
  10. HP Pavilion dv6-6180us Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Remove screen frame.
  11. HP Pavilion dv6-6180us Screen Replacement: 11 단계, 이미지 2개 중 1개 HP Pavilion dv6-6180us Screen Replacement: 11 단계, 이미지 2개 중 2개
    • Unscrew two 3mm screws using PH 1 screwdriver
    • Eight 6mm screws using PH 1 screwdriver.
    • Use PH 000 screwdriver to remove two 4mm screws.
  12. HP Pavilion dv6-6180us Screen Replacement: 12 단계, 이미지 1개 중 1개
    • Pry open the keyboard using plastic opening tool starting from the top.
    • Lift up keyboard gently because a silver ribbon is still attaching it to the laptop.
  13. HP Pavilion dv6-6180us Screen Replacement: 13 단계, 이미지 3개 중 1개 HP Pavilion dv6-6180us Screen Replacement: 13 단계, 이미지 3개 중 2개 HP Pavilion dv6-6180us Screen Replacement: 13 단계, 이미지 3개 중 3개
    • Place keyboard upside down.
    • Lift up plastic cover over keyboard connector cable.
    • Pull ribbon cable up away from keyboard to completely remove.
  14. HP Pavilion dv6-6180us Screen Replacement: 14 단계, 이미지 1개 중 1개
    • Remove seven 4mm pannel screws with PH 1 screwdriver.
  15. HP Pavilion dv6-6180us Screen Replacement: 15 단계, 이미지 1개 중 1개
    • Place the computer on its side.
    • Separate top panel from bottom frame.
  16. HP Pavilion dv6-6180us Screen Replacement: 16 단계, 이미지 2개 중 1개 HP Pavilion dv6-6180us Screen Replacement: 16 단계, 이미지 2개 중 2개
    • Pop open rest palm assembly.
  17. HP Pavilion dv6-6180us Screen Replacement: 17 단계, 이미지 1개 중 1개
    • Pull ribbon to detach from bottom panel.
  18. HP Pavilion dv6-6180us Screen Replacement: 18 단계, 이미지 1개 중 1개
    • Remove two 5mm screws securing fan, using HP 1 screwdriver.
  19. HP Pavilion dv6-6180us Screen Replacement: 19 단계, 이미지 1개 중 1개
    • Flip laptop over.
    • Remove two 4mm screws securing antenna using PH 1 screwdriver.
    • Pull antenna to the right to remove.
  20. HP Pavilion dv6-6180us Screen Replacement: 20 단계, 이미지 1개 중 1개
    • Flip laptop side up.
    • Pull off yellow insulating tape.
  21. HP Pavilion dv6-6180us Screen Replacement: 21 단계, 이미지 2개 중 1개 HP Pavilion dv6-6180us Screen Replacement: 21 단계, 이미지 2개 중 2개
    • Grab tab on left top corner and remove black wire.
    • Remove white input attachment.
  22. HP Pavilion dv6-6180us Screen Replacement: 22 단계, 이미지 1개 중 1개
    • Lift up speaker.
  23. HP Pavilion dv6-6180us Screen Replacement: 23 단계, 이미지 1개 중 1개
    • Hold the motherboard and pull to the right.
    • The plugs on the left may be difficult to snap out.
  24. HP Pavilion dv6-6180us Screen Replacement: 24 단계, 이미지 1개 중 1개
    • Remove a 4mm screw securing wire attachment using PH 1 screwdriver.
  25. HP Pavilion dv6-6180us Screen Replacement: 25 단계, 이미지 1개 중 1개
    • Remove two hinge covers.
  26. HP Pavilion dv6-6180us Screen Replacement: 26 단계, 이미지 1개 중 1개
    • Unhook the antenna wire from behind hinge.
  27. HP Pavilion dv6-6180us Screen Replacement: 27 단계, 이미지 1개 중 1개
    • Lay screen face down.
    • Detach silver wire from screen
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
michelle pulido
회원 가입일: 09/15/16
859 평판
안내서 4개를 작성함
CSU Fullerton, Team 1-2, Bruce Fall 2016 CSU Fullerton, Team 1-2, Bruce Fall 2016 회원
CSUF-BRUCE-F16S1G2
4 회원들
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 17
전체 시간: 1,695
