주요 콘텐츠로 건너뛰기
iFixit은 쿠키를 사용하여 사이트 기능을 개선하고 트래픽을 분석하며 광고를 개인화합니다. 당사 사이트를 사용함으로써 귀하는 당사의 쿠키 사용 및 개인정보 취급방침에 동의하게 됩니다.
HP Pavilion dv6-6c51ca Service Cover Replacement
Cokyaw
Cokyaw2 다른 기여자
최종 수정일 August 6, 2024
1 - 2 분
쉬움
커뮤니티-기여 안내서
필요한 것
도구
  1. HP Pavilion dv6-6c51ca Service Cover Replacement, Remove the battery: 1 단계, 이미지 3개 중 1개 HP Pavilion dv6-6c51ca Service Cover Replacement, Remove the battery: 1 단계, 이미지 3개 중 2개 HP Pavilion dv6-6c51ca Service Cover Replacement, Remove the battery: 1 단계, 이미지 3개 중 3개
    • Make sure to turn off the computer and unplug the AC adapter from the computer. It is good practice to remove the battery and any other power source before working with any internal part in your computer.
    • REMOVING THE BATTERY: Flip the laptop over with the battery side facing up.
    • Slide the battery release latch to release the battery.
    • Pivot the front edge of the battery up and back.
    • Remove the battery.
    • REPLACING THE BATTERY: Align the tabs on the rear edge of the battery with the notches on the rear edge of the battery bay.
    • Pivot the front edge of the battery down into the battery bay until it is fully seated. (The battery release latch will automatically lock into place.)
    • Battery part number: 593554-001
  2. HP Pavilion dv6-6c51ca Service Cover Replacement, Remove the service cover: 2 단계, 이미지 3개 중 1개 HP Pavilion dv6-6c51ca Service Cover Replacement, Remove the service cover: 2 단계, 이미지 3개 중 2개 HP Pavilion dv6-6c51ca Service Cover Replacement, Remove the service cover: 2 단계, 이미지 3개 중 3개
    • Note: As as safety feature, the service cover cannot be removed without removing the battery first.
    • Slide the service cover release latch to release the service cover.
    • Lift the rear edge of the service cover up and forward until it rests at an angle, being careful not to break the small plastic tabs that hold the cover in place. (A plastic spudger can be used to release the tabs)
    • Remove the service cover.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Cokyaw
회원 가입일: 10/13/18
512 평판
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 7
전체 시간: 211
