주요 콘텐츠로 건너뛰기
HP Pavilion dv6500 Touchpad Replacement
Andrew
Andrew4 다른 기여자
최종 수정일 December 21, 2016
20 분
조정
This guide contains the necessary steps to replace the HP Pavilion dv6500 trackpad.
필요한 것
도구
  1. HP Pavilion dv6500 Touchpad Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Flip computer face down.
  2. HP Pavilion dv6500 Touchpad Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery by sliding the button to the side.
    • Be careful if the battery is leaking or appears punctured in anyway. Battery acid is harmful and may cause burns.
  3. HP Pavilion dv6500 Touchpad Replacement, Back Panel: 3 단계, 이미지 1개 중 1개
    • Remove fifteen 7.0mm PH0 screws.
    • Remove five silver 4.0mm PH 0 screws inside the cavity for the battery.
  4. HP Pavilion dv6500 Touchpad Replacement, Keyboard: 4 단계, 이미지 2개 중 1개 HP Pavilion dv6500 Touchpad Replacement, Keyboard: 4 단계, 이미지 2개 중 2개
    • Gently lift the plastic panel on the top of the laptop at the divide until the two ribbon cables and cable leads are visible with their ports on left side on laptop.
  5. HP Pavilion dv6500 Touchpad Replacement: 5 단계, 이미지 1개 중 1개
    • Gently pull on the 2 ribbon cables until they detach from the computer.
    • Unplug cables connecting the top keyboard assembly and computer body.
    • Be careful not to rip the speaker cables.
  6. HP Pavilion dv6500 Touchpad Replacement: 6 단계, 이미지 1개 중 1개
    • The top of the keyboard should be exposed enough to unclip and slide the keyboard out from the clips near the trackpad on the laptop.
    • Gently pull the flat black cable toward the monitor to remove the cable from the motherboard, freeing the keyboard.
    • Be careful not to pull too hard and damage the black cable.
  7. HP Pavilion dv6500 Touchpad Replacement: 7 단계, 이미지 1개 중 1개
    • Insert new keyboard by sliding it into place of original keyboard and clipping into place near top of trackpad.
  8. HP Pavilion dv6500 Touchpad Replacement, Touchpad: 8 단계, 이미지 1개 중 1개
    • Using the size 5.0mm hex tool, unscrew the 2 brass screws located near the RAM cards under the laptop.
  9. HP Pavilion dv6500 Touchpad Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the 4 7mm screws holding the metal plate to the rest of the laptop.
    • Lift the metal plate off the laptop and turn over to reveal the underside of the mouse pad
  10. HP Pavilion dv6500 Touchpad Replacement: 10 단계, 이미지 3개 중 1개 HP Pavilion dv6500 Touchpad Replacement: 10 단계, 이미지 3개 중 2개 HP Pavilion dv6500 Touchpad Replacement: 10 단계, 이미지 3개 중 3개
    • Flip the metal plate over to expose the screws holding the keypad in place.
    • Remove the 6 7.0mm screws holding the mousepad in place.
  11. HP Pavilion dv6500 Touchpad Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the 4 7mm screws, 2 on either side of the mouse pad.
결론
작성자
4다른 기여자 명과 함께
Andrew
회원 가입일: 10/23/16
392 평판
안내서 3개를 작성함
UMass Dartmouth, Team 1-6, Catania Fall 2016 UMass Dartmouth, Team 1-6, Catania Fall 2016 회원
UMASSD-CATANIA-F16S1G6
3 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 1,101
