주요 콘텐츠로 건너뛰기
HP Pavilion dv7-1448dx Battery Replacement
Kirsten Gilliland
Kirsten Gilliland3 다른 기여자
최종 수정일 April 9, 2019
1 - 2 분
매우 쉬움
This guide provides instructions for replacing the battery. This may be a solution if your computer is experiencing sluggish charging or is not holding a charge.
  1. HP Pavilion dv7-1448dx Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure the computer is unplugged and turned off.
    • Place the computer front side down with the battery compartment farthest away.
  2. HP Pavilion dv7-1448dx Battery Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion dv7-1448dx Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the switch under the battery compartment to the left until the compartment opens. This may require some force.
  3. HP Pavilion dv7-1448dx Battery Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion dv7-1448dx Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Lightly pry the battery upward to remove.
    • When reinserting the battery, match the latches along the backside of the battery with the corresponding slots in the computer in order to press it into place.
결론
To reinsert a new battery, follow these instructions in reverse order.
작성자
3다른 기여자 명과 함께
Kirsten Gilliland
회원 가입일: 01/30/17
741 평판
안내서 4개를 작성함
Baylor, Team 3-5, Whitney Spring 2017 Baylor, Team 3-5, Whitney Spring 2017 회원
BU-WHITNEY-S17S3G5
2 회원들
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 275
