주요 콘텐츠로 건너뛰기
HP Pavilion dv7-3065dx Disk Drive Replacement
Bailey York
Bailey York다른 한 명의 기여자
최종 수정일 May 11, 2017
3 - 5 분
쉬움
This guide will instruct you on how to replace the disk drive for the HP Pavilion dv7-3065dx. This is located on the side of the computer and is a quick fix!
필요한 것
도구
  1. HP Pavilion dv7-3065dx Disk Drive Replacement, Disk Drive: 1 단계, 이미지 2개 중 1개 HP Pavilion dv7-3065dx Disk Drive Replacement, Disk Drive: 1 단계, 이미지 2개 중 2개
    • Remove the Battery as a safety precaution
    • There is a latch identified in the picture. By sliding this latch to the left, the battery is released from a lock position.
  2. HP Pavilion dv7-3065dx Disk Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Use a Philips screwdriver to unscrew one screw holding the disk drive to the laptop.
    • In the photo there is a covering missing from another piece of the laptop but this will not impact the disk drive.
  3. HP Pavilion dv7-3065dx Disk Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Slide (pull) the disk drive out from the laptop and place it off to the side.
    • The disk drive is the silver container as seen in the photo.
결론
작성자
1다른 기여자 명과 함께
Bailey York
회원 가입일: 02/07/17
101 평판
안내서 1개를 작성함
Ohio State, Team 1-5, Wilder Spring 2017 Ohio State, Team 1-5, Wilder Spring 2017 회원
OSU-WILDER-S17S1G5
4 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 3
전체 시간: 791
