주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Pavilion dv7-3065dx RAM Replacement
Jonathan Winkler
Jonathan Winkler다른 한 명의 기여자
최종 수정일 2017년 5월 11일
8 분
조정
액션 샷
더 나은 이미지가 필요함
RAM is an essential Computing Module. Having faulty RAM will cause your computer to not work, and increasing the amount of RAM can make your computer work faster. The HP Pavilion dv7-3065dx can utilize a maximum of 8 GB of total RAM, and comes with a standard 4GB.
필요한 것
부품
도구
더보기...
  1. HP Pavilion dv7-3065dx RAM Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Pavilion dv7-3065dx RAM Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn off the device before removing the battery.
    • Place the laptop upside down on a flat surface so that the bottom is facing up.
    • The battery is the long rectangle above the latch.
  2. HP Pavilion dv7-3065dx RAM Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the battery latch to the left to release the battery.
  3. HP Pavilion dv7-3065dx RAM Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion dv7-3065dx RAM Replacement: 3 단계, 이미지 2개 중 2개
    • Carefully pull out the battery while holding the latch to the open position with your finger.
  4. HP Pavilion dv7-3065dx RAM Replacement, RAM: 4 단계, 이미지 1개 중 1개
    • Remove the four circled screws using a #1 philips head screwdriver
    • Note: Be sure to leave the screws in the pannel
    • Pry off cover and place to the side.
  5. HP Pavilion dv7-3065dx RAM Replacement: 5 단계, 이미지 1개 중 1개
    • The RAM modules will be found on the right side of the access panel
    • CAUTION - The RAM modules are sensitive to electrostatic discharge. It is recommended to wear an anti static bracelet while handling the RAM.
  6. HP Pavilion dv7-3065dx RAM Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion dv7-3065dx RAM Replacement: 6 단계, 이미지 2개 중 2개
    • To remove RAM modules, pry metal tabs out of the modules, and pull ram out (Starting from the top RAM module).
    • Note: The RAM Modules pop out away from the motherboard. In order to replace them, slot the gold plated end into the terminal and push down towards the motherboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
향후 수리를 위한 준비
모두 쇼핑하기
작성자
1다른 기여자 명과 함께
Jonathan Winkler
회원 가입일: 02/06/17
161 평판
안내서 1개를 작성함
Ohio State, Team 1-5, Wilder Spring 2017 Ohio State, Team 1-5, Wilder Spring 2017 회원
OSU-WILDER-S17S1G5
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 20
전체 시간: 1,471
