주요 콘텐츠로 건너뛰기
HP Pavilion dv7-6163us Touchpad Replacement
필요한 것
  1. HP Pavilion dv7-6163us  Touchpad Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the device over so that the bottom is facing up.
  2. HP Pavilion dv7-6163us  Touchpad Replacement: 2 단계, 이미지 1/1
    • Place your finger on the battery release latch and slide it to the right to release the battery.
    • The battery will pop up after sliding the latch.
  3. HP Pavilion dv7-6163us  Touchpad Replacement: 3 단계, 이미지 1/1
    • Firmly grasp the battery and remove it from the device.
  4. HP Pavilion dv7-6163us  Touchpad Replacement, Touchpad: 4 단계, 이미지 1/2 HP Pavilion dv7-6163us  Touchpad Replacement, Touchpad: 4 단계, 이미지 2/2
    • Remove service door by prying the plastic opening tool or the spudger under the door.
    • Lift door and set aside.
  5. HP Pavilion dv7-6163us  Touchpad Replacement: 5 단계, 이미지 1/3 HP Pavilion dv7-6163us  Touchpad Replacement: 5 단계, 이미지 2/3 HP Pavilion dv7-6163us  Touchpad Replacement: 5 단계, 이미지 3/3
    • Remove the single screw securing the optical drive in place.
    • Detach the optical drive by sliding your fingers between the drive and the body of the laptop.
    • Pull out the optical drive.
  6. HP Pavilion dv7-6163us  Touchpad Replacement: 6 단계, 이미지 1/1
    • Remove all visible screws:
    • Remove the four 10 mm screws (one at each corner).
    • Remove the remaining twenty-five 3 mm screws.
  7. HP Pavilion dv7-6163us  Touchpad Replacement: 7 단계, 이미지 1/3 HP Pavilion dv7-6163us  Touchpad Replacement: 7 단계, 이미지 2/3 HP Pavilion dv7-6163us  Touchpad Replacement: 7 단계, 이미지 3/3
    • Turn the laptop right side up and open the screen.
    • Use the plastic opening tool to loosen and remove the keyboard. Begin in the middle top of the keyboard and work around the edges.
    • The keyboard will snap out, but do not remove it completely. It is still attached to the device by a ribbon cable.
  8. HP Pavilion dv7-6163us  Touchpad Replacement: 8 단계, 이미지 1/2 HP Pavilion dv7-6163us  Touchpad Replacement: 8 단계, 이미지 2/2
    • Flip up the keyboard to access the ribbon cable underneath.
    • Disconnect the keyboard ribbon cable from the motherboard.
    • Remove the keyboard.
  9. HP Pavilion dv7-6163us  Touchpad Replacement: 9 단계, 이미지 1/3 HP Pavilion dv7-6163us  Touchpad Replacement: 9 단계, 이미지 2/3 HP Pavilion dv7-6163us  Touchpad Replacement: 9 단계, 이미지 3/3
    • Release the faceplate with your fingers or a spudger. Begin at the top left corner and work your way around to snap the faceplate away from the body of the laptop.
    • Turn over the face plate to access the underside of the touchpad.
  10. HP Pavilion dv7-6163us  Touchpad Replacement: 10 단계, 이미지 1/3 HP Pavilion dv7-6163us  Touchpad Replacement: 10 단계, 이미지 2/3 HP Pavilion dv7-6163us  Touchpad Replacement: 10 단계, 이미지 3/3
    • Disconnect three ribbon cables.
    • Remove the eight screws securing the touchpad plate.
    • Remove the touchpad plate.
  11. HP Pavilion dv7-6163us  Touchpad Replacement: 11 단계, 이미지 1/3 HP Pavilion dv7-6163us  Touchpad Replacement: 11 단계, 이미지 2/3 HP Pavilion dv7-6163us  Touchpad Replacement: 11 단계, 이미지 3/3
    • Pop out the touchpad using a plastic opening tool. The edges should snap out of place.
    • Remove the touchpad.
결론
Kaylee Cort
회원 가입일: 01/16/19
169 평판
안내서 1개 작성함
University of Alabama, Team S1-G2, Bedsole Spring 2019 University of Alabama, Team S1-G2, Bedsole Spring 2019 회원
UA-BEDSOLE-S19S1G2
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 25
전체 시간: 1,016
