주요 콘텐츠로 건너뛰기
HP Pavilion dv7-6163us  Touchpad Replacement
Kaylee Cort
Kaylee Cort4 다른 기여자
최종 수정일 June 28, 2019
2 시간
조정
This guide will instruct you how to remove the touchpad and replace by reversing the steps. There may be some sharp corners underneath you should be cautious of. You may need to replace the touchpad if it has a slow or no response upon placing your finger on the touchpad and moving it.
필요한 것
도구
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
더보기...
  1. HP Pavilion dv7-6163us  Touchpad Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the device over so that the bottom is facing up.
  2. HP Pavilion dv7-6163us  Touchpad Replacement: 2 단계, 이미지 1개 중 1개
    • Place your finger on the battery release latch and slide it to the right to release the battery.
    • The battery will pop up after sliding the latch.
  3. HP Pavilion dv7-6163us  Touchpad Replacement: 3 단계, 이미지 1개 중 1개
    • Firmly grasp the battery and remove it from the device.
  4. HP Pavilion dv7-6163us  Touchpad Replacement, Touchpad: 4 단계, 이미지 2개 중 1개 HP Pavilion dv7-6163us  Touchpad Replacement, Touchpad: 4 단계, 이미지 2개 중 2개
    • Remove service door by prying the plastic opening tool or the spudger under the door.
    • Lift door and set aside.
  5. HP Pavilion dv7-6163us  Touchpad Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion dv7-6163us  Touchpad Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion dv7-6163us  Touchpad Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the single screw securing the optical drive in place.
    • Detach the optical drive by sliding your fingers between the drive and the body of the laptop.
    • Pull out the optical drive.
  6. HP Pavilion dv7-6163us  Touchpad Replacement: 6 단계, 이미지 1개 중 1개
    • Remove all visible screws:
    • Remove the four 10 mm screws (one at each corner).
    • Remove the remaining twenty-five 3 mm screws.
  7. HP Pavilion dv7-6163us  Touchpad Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion dv7-6163us  Touchpad Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion dv7-6163us  Touchpad Replacement: 7 단계, 이미지 3개 중 3개
    • Turn the laptop right side up and open the screen.
    • Use the plastic opening tool to loosen and remove the keyboard. Begin in the middle top of the keyboard and work around the edges.
    • The keyboard will snap out, but do not remove it completely. It is still attached to the device by a ribbon cable.
  8. HP Pavilion dv7-6163us  Touchpad Replacement: 8 단계, 이미지 2개 중 1개 HP Pavilion dv7-6163us  Touchpad Replacement: 8 단계, 이미지 2개 중 2개
    • Flip up the keyboard to access the ribbon cable underneath.
    • Disconnect the keyboard ribbon cable from the motherboard.
    • Remove the keyboard.
  9. HP Pavilion dv7-6163us  Touchpad Replacement: 9 단계, 이미지 3개 중 1개 HP Pavilion dv7-6163us  Touchpad Replacement: 9 단계, 이미지 3개 중 2개 HP Pavilion dv7-6163us  Touchpad Replacement: 9 단계, 이미지 3개 중 3개
    • Release the faceplate with your fingers or a spudger. Begin at the top left corner and work your way around to snap the faceplate away from the body of the laptop.
    • Turn over the face plate to access the underside of the touchpad.
  10. HP Pavilion dv7-6163us  Touchpad Replacement: 10 단계, 이미지 3개 중 1개 HP Pavilion dv7-6163us  Touchpad Replacement: 10 단계, 이미지 3개 중 2개 HP Pavilion dv7-6163us  Touchpad Replacement: 10 단계, 이미지 3개 중 3개
    • Disconnect three ribbon cables.
    • Remove the eight screws securing the touchpad plate.
    • Remove the touchpad plate.
  11. HP Pavilion dv7-6163us  Touchpad Replacement: 11 단계, 이미지 3개 중 1개 HP Pavilion dv7-6163us  Touchpad Replacement: 11 단계, 이미지 3개 중 2개 HP Pavilion dv7-6163us  Touchpad Replacement: 11 단계, 이미지 3개 중 3개
    • Pop out the touchpad using a plastic opening tool. The edges should snap out of place.
    • Remove the touchpad.
결론
작성자
4다른 기여자 명과 함께
Kaylee Cort
회원 가입일: 01/16/19
169 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 21
전체 시간: 1,087
