주요 콘텐츠로 건너뛰기
HP Pavilion dv7t-7000 Motherboard Replacement
emmanuella Dickson-itua
emmanuella Dickson-itua2 다른 기여자
최종 수정일 June 13, 2018
30 - 50 분
조정
더 나은 소개글
A replacement guide for the motherboard of the HP Pavilion dv7t-7000
필요한 것
도구
더보기...
  1. HP Pavilion dv7t-7000 Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 Motherboard Replacement, Back Panel: 4 단계, 이미지 1개 중 1개
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 Motherboard Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion dv7t-7000 Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 Motherboard Replacement, Keyboard: 6 단계, 이미지 2개 중 1개 HP Pavilion dv7t-7000 Motherboard Replacement, Keyboard: 6 단계, 이미지 2개 중 2개
    • Remove the single Phillips #00 screw.
    • Flip the laptop over.
  7. HP Pavilion dv7t-7000 Motherboard Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion dv7t-7000 Motherboard Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion dv7t-7000 Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • Wedge a spudger in between the keyboard and the upper bezel (nearest the screen).
    • Pry upward to release the keyboard clips.
    • The keyboard is plugged into the motherboard, so be careful not to pull out while lifting keyboard.
  8. HP Pavilion dv7t-7000 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to flip up the black tab on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors.
    • Remove the keyboard.
  9. HP Pavilion dv7t-7000 Motherboard Replacement, RAM: 9 단계, 이미지 2개 중 1개 HP Pavilion dv7t-7000 Motherboard Replacement, RAM: 9 단계, 이미지 2개 중 2개
    • Push the retraining springs away from the RAM at the same time to unlock the RAM.
  10. HP Pavilion dv7t-7000 Motherboard Replacement: 10 단계, 이미지 2개 중 1개 HP Pavilion dv7t-7000 Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Pull the RAM out.
    • Follow the same procedure for the additional RAM.
  11. HP Pavilion dv7t-7000 Motherboard Replacement, Wi-Fi Card: 11 단계, 이미지 2개 중 1개 HP Pavilion dv7t-7000 Motherboard Replacement, Wi-Fi Card: 11 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pop off the antenna connectors.
  12. HP Pavilion dv7t-7000 Motherboard Replacement: 12 단계, 이미지 3개 중 1개 HP Pavilion dv7t-7000 Motherboard Replacement: 12 단계, 이미지 3개 중 2개 HP Pavilion dv7t-7000 Motherboard Replacement: 12 단계, 이미지 3개 중 3개
    • Remove single Phillips #00 screw.
    • Pull the card out by hand.
  13. HP Pavilion dv7t-7000 Motherboard Replacement, Palm Rest: 13 단계, 이미지 3개 중 1개 HP Pavilion dv7t-7000 Motherboard Replacement, Palm Rest: 13 단계, 이미지 3개 중 2개 HP Pavilion dv7t-7000 Motherboard Replacement, Palm Rest: 13 단계, 이미지 3개 중 3개
    • Flip the keyboard back over.
    • Remove the single Phillips #00 screw holding in the CD drive.
    • Pull out the CD drive.
  14. HP Pavilion dv7t-7000 Motherboard Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the seventeen Phillips #00 screws securing the back panel to the laptop.
  15. HP Pavilion dv7t-7000 Motherboard Replacement: 15 단계, 이미지 2개 중 1개 HP Pavilion dv7t-7000 Motherboard Replacement: 15 단계, 이미지 2개 중 2개
  16. HP Pavilion dv7t-7000 Motherboard Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the panel by lifting it up.
  17. HP Pavilion dv7t-7000 Motherboard Replacement, Motherboard: 17 단계, 이미지 1개 중 1개
    • Remove the eleven Phillips #00 screws.
  18. HP Pavilion dv7t-7000 Motherboard Replacement: 18 단계, 이미지 3개 중 1개 HP Pavilion dv7t-7000 Motherboard Replacement: 18 단계, 이미지 3개 중 2개 HP Pavilion dv7t-7000 Motherboard Replacement: 18 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to disconnect all wires connected to the motherboard.
  19. HP Pavilion dv7t-7000 Motherboard Replacement: 19 단계, 이미지 2개 중 1개 HP Pavilion dv7t-7000 Motherboard Replacement: 19 단계, 이미지 2개 중 2개
    • Lift up the black tab on the ZIF connector with the flat end of a spudger.
    • Pull the ribbon cable out of the ZIF connector.
    • Remove the fan from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
회원 가입일: 02/21/18
121 평판
안내서 1개를 작성함
댓글 한 개
Hello guys
I'm searching for a Bottom Base Case for HP Envy DV7 Pavilion
Does anyone know where to find it?
Ri Ma - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 1,143
