주요 콘텐츠로 건너뛰기
HP Pavilion dv7t-7000 Speaker Replacement
Nabin Bhatta
Nabin Bhatta다른 한 명의 기여자
최종 수정일 June 13, 2018
30 분
조정
더 나은 소개글
How to replace the speaker on a HP Pavilion dv7t-7000 laptop.
필요한 것
도구
  1. HP Pavilion dv7t-7000 Speaker Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 Speaker Replacement: 3 단계, 이미지 1개 중 1개
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 Speaker Replacement, Back Panel: 4 단계, 이미지 1개 중 1개
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 Speaker Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion dv7t-7000 Speaker Replacement: 5 단계, 이미지 2개 중 2개
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 Speaker Replacement, Keyboard: 6 단계, 이미지 2개 중 1개 HP Pavilion dv7t-7000 Speaker Replacement, Keyboard: 6 단계, 이미지 2개 중 2개
    • Remove the single Phillips #00 screw.
    • Flip the laptop over.
  7. HP Pavilion dv7t-7000 Speaker Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion dv7t-7000 Speaker Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion dv7t-7000 Speaker Replacement: 7 단계, 이미지 3개 중 3개
    • Wedge a spudger in between the keyboard and the upper bezel (nearest the screen).
    • Pry upward to release the keyboard clips.
    • The keyboard is plugged into the motherboard, so be careful not to pull out while lifting keyboard.
  8. HP Pavilion dv7t-7000 Speaker Replacement: 8 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to flip up the black tab on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors.
    • Remove the keyboard.
  9. HP Pavilion dv7t-7000 Speaker Replacement, Speaker: 9 단계, 이미지 3개 중 1개 HP Pavilion dv7t-7000 Speaker Replacement, Speaker: 9 단계, 이미지 3개 중 2개 HP Pavilion dv7t-7000 Speaker Replacement, Speaker: 9 단계, 이미지 3개 중 3개
    • Use Phillips #00 to unscrew the screw and take off the front panel.
  10. HP Pavilion dv7t-7000 Speaker Replacement: 10 단계, 이미지 2개 중 1개 HP Pavilion dv7t-7000 Speaker Replacement: 10 단계, 이미지 2개 중 2개
    • The speaker is located at the back side of the front panel.
    • Unscrew two screws located at the speaker.
  11. HP Pavilion dv7t-7000 Speaker Replacement: 11 단계, 이미지 1개 중 1개
    • Pull out the speakers to remove.
결론
작성자
1다른 기여자 명과 함께
Nabin Bhatta
회원 가입일: 02/11/18
273 평판
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 1,401
