주요 콘텐츠로 건너뛰기
HP Pavilion x360 14m-cd0003dx Fan Replacement
Riley McMorrow
Riley McMorrow2 다른 기여자
최종 수정일 May 25, 2022
10 분
조정
This guide helps you with removal and replacing the Heat Sink and Fan for HP Pavilion x360 14m-cd0003dx laptop. If your computer is getting heated too often during the use, it may need to be replaced.
For further information to determine if the Heat Sink and Fan needs to be replaced, please refer to this troubleshooting guide.
필요한 것
도구
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  • Phillips #00 Screwdriver
더보기...
  1. HP Pavilion x360 14m-cd0003dx Fan Replacement, Heat Sink and Fan: 1 단계, 이미지 1개 중 1개
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Fan Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-cd0003dx Fan Replacement: 2 단계, 이미지 2개 중 2개
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx Fan Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-cd0003dx Fan Replacement: 3 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove the seven 5 mm screws that secure the fan and heatsink.
  4. HP Pavilion x360 14m-cd0003dx Fan Replacement: 4 단계, 이미지 1개 중 1개
    • Peel back the retention tape that secures the heat sink assembly.
  5. HP Pavilion x360 14m-cd0003dx Fan Replacement: 5 단계, 이미지 1개 중 1개
    • Disconnect the fan cable from the connector on the system board.
  6. HP Pavilion x360 14m-cd0003dx Fan Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the heat sink assembly from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Riley McMorrow
회원 가입일: 03/22/22
273 평판
안내서 1개를 작성함
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 회원
UMASSD-SINCLAIRE-S22S7G4
6 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 15
전체 시간: 546
