HP Pavilion zv5000 Screen Replacement
Are you having trouble seeing anything on your screen? Is your screen perpetually black, even when plugged in and charged? If so, replacing your screen may bring visuals back to your life.
Make sure that your device is properly shut down and unplugged from any outlet.
Flip Pavilion over so that the bottom faces up and locate the battery in the bottom left corner.
Using a Phillips #0 screwdriver, unscrew all four Phillips PM 2.5X13.0mm screws and place in a secure area until the end of the project.
다른 2명이 해당 안내서를 완성하였습니다.
