주요 콘텐츠로 건너뛰기
HP ProDesk 400 G5 Mini RAM Replacement / Upgrade
Sam Manshouri
Sam Manshouri4 다른 기여자
최종 수정일 October 1, 2024
15 - 30 분
쉬움
추천 학생 안내서
This guide will help you easily replace and/or upgrade the RAM on your HP ProDesk 400 G5 Desktop Mini PC. This repair may be needed if you have troubleshot your computer and found that the RAM is corrupted or out space. You may also want to upgrade your RAM for faster speed. Overall, it can help your computer run more quickly and smoothly. Upgrading and replacing your existing RAM is the same process.
Before beginning this repair, turn off your computer and disconnect from all peripherals and the AC adapter.
필요한 것
  1. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade, RAM: 1 단계, 이미지 3개 중 1개 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade, RAM: 1 단계, 이미지 3개 중 2개 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade, RAM: 1 단계, 이미지 3개 중 3개
    • Turn the device around the back is facing you.
    • See the large screw in the center back of the PC.
  2. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: 2 단계, 이미지 3개 중 1개 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: 2 단계, 이미지 3개 중 2개 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: 2 단계, 이미지 3개 중 3개
    • Remove the thumbscrew holding the back panel onto the PC.
  3. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: 3 단계, 이미지 3개 중 1개 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: 3 단계, 이미지 3개 중 2개 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: 3 단계, 이미지 3개 중 3개
    • Slide the top panel off away from the back of the device.
    • Then, carefully lift it upwards to remove it.
  4. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: 4 단계, 이미지 3개 중 1개 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: 4 단계, 이미지 3개 중 2개 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: 4 단계, 이미지 3개 중 3개
    • Gently lift the main fan to expose the RAM modules.
  5. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: 5 단계, 이미지 3개 중 1개 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: 5 단계, 이미지 3개 중 2개 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: 5 단계, 이미지 3개 중 3개
    • Using your fingers, pull the metal arms (located on both sides of the RAM module) slightly away from it, to release it from the slot.
    • The RAM will pop up by a few millimeters.
    • Remove it at an angle and not straight up so you don't damage the socket.
  6. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: 6 단계, 이미지 3개 중 1개 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: 6 단계, 이미지 3개 중 2개 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: 6 단계, 이미지 3개 중 3개
    • To insert a new RAM stick, line up the indent on the RAM with the indent on the slot, then slide it in.
  7. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: 7 단계, 이미지 3개 중 1개 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: 7 단계, 이미지 3개 중 2개 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: 7 단계, 이미지 3개 중 3개
    • Push the RAM stick down flat once it's securely attached to the socket.
    • You should hear a tactile click which indicates it was installed correctly.
    • Make sure the arms on both sides go back to their locked position.
  8. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: 8 단계, 이미지 3개 중 1개 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: 8 단계, 이미지 3개 중 2개 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: 8 단계, 이미지 3개 중 3개
    • After RAM installation, place the fan back on top of the RAM and replace the panel by sliding it into place and tightening it with the thumbscrew.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Sam Manshouri
회원 가입일: 02/01/23
187 평판
안내서 1개를 작성함
York University, Team M-17, Allen Winter 2023 York University, Team M-17, Allen Winter 2023 회원
YORK-ALLEN-W23SMG17
1 회원
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 63
지난 30일: 215
전체 시간: 3,912
