소개
This guide shows how to remove and replace a worn battery for the HP Spectre x360 15t-ap000 laptop.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
필요한 것
Use a T5 driver to remove the following screws securing the back cover:
Six 4 mm-long screws
Two 7.8 mm-long screws
Use an opening tool or your fingers to pry up the back cover from the laptop.
Pry the edges of the battery connector with a spudger to loosen the connector from its motherboard socket.
Gently pull the connector parallel to the motherboard to disconnect it.
Use a Phillips screwdriver to remove the five 4.3 mm-long screws securing the battery to the laptop.
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 4개
I have the same model, but there are screws under the two rear rubber feet. I damaged one of the feet during removal ):
I'm sorry to hear that! I double-checked my laptop, and it doesn't have the two feet. Perhaps there was a hardware update. I'll add a note in the guides.
So the battery shown/listed in the store is a PK03XL but the images (and my laptop) clearly have the PG03XL model which has higher amp hours. Also, the PK0 does not fit.
Hi Karim,
That's correct! The PK03XL battery that's sold in the iFixit store is for the 13" HP Spectre. This guide is written for the 15" HP Spectre.
