HP Touchsmart IQ506 Stand Replacement
Replacing the stand on the HP IQ506.
The part number for the stand this system uses is the HP 507866-001 stand. Note: This part does not include screws. You will need to get the diameter with a digital caliper if you do not have the screws. I DO NOT have this information to hand right now.
Unscrew the RAM door from the system. Use a Phillips #1 screwdriver. Once you do this, unclip it from the bottom and pull forward.
Remove the stand from the system. Use a Phillips #1 screwdriver to loosen the 4 screws. The stand will be loose and easily removed.
