주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement
필요한 것
    1. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Batteries: 1 단계, 이미지 3개 중 1개 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Batteries: 1 단계, 이미지 3개 중 2개 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Batteries: 1 단계, 이미지 3개 중 3개
      • Slide the rear compartment cover in the direction of the arrow.
      • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
      댓글 쓰기
    1. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Shell: 2 단계, 이미지 2개 중 1개 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Shell: 2 단계, 이미지 2개 중 2개
      • Remove the four 4mm screws using a Phillips #00 screwdriver.
      댓글 쓰기
    2. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: 3 단계, 이미지 3개 중 1개 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: 3 단계, 이미지 3개 중 2개 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: 3 단계, 이미지 3개 중 3개
      • Grip the main body and pull the joystick outwards until the entire front panel pops off.
      • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
      댓글 쓰기
    3. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: 4 단계, 이미지 2개 중 1개 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: 4 단계, 이미지 2개 중 2개
      • Use a spudger to pry apart the two halves of the assembly.
      • Work slowly, prying a small section at a time until the halves are completely separated.
      댓글 쓰기
    1. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Small Circuit Board: 5 단계, 이미지 2개 중 1개 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Small Circuit Board: 5 단계, 이미지 2개 중 2개
      • Using a Phillips #00 screwdriver, remove the four 4mm screws located on the joystick circuit board underneath the top half of the controller.
      댓글 쓰기
    2. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: 6 단계, 이미지 3개 중 1개 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: 6 단계, 이미지 3개 중 2개 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: 6 단계, 이미지 3개 중 3개
      • Remove the orange flat cable by pulling the orange tab parallel to the circuit board.
      • Release the blue flat cable by lifting up the white latch with a spudger.
      댓글 쓰기
    1. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Joystick Switch: 7 단계, 이미지 2개 중 1개 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Joystick Switch: 7 단계, 이미지 2개 중 2개
      • The joystick controller is soldered directly to the circuit board. You can find instructions for removing soldered components here.
      • The joystick controller is secured by 12 solder connections. Once these have been desoldered, the controller can be removed.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Clement Cheung
회원 가입일: 01/24/19
643 평판
안내서 5개를 작성함
Cal Poly, Team S18-G5, White Winter 2019 Cal Poly, Team S18-G5, White Winter 2019 회원
CPSU-WHITE-W19S18G5
2 회원들
안내서 20개를 작성함
3가이드 댓글
You can solder replacement Xbox One analog sticks right? I have some stick drift and can’t test this until my university reopens, but when it does I want to try fixing it.
Edit: I have the Dell controllers but they seem identical to the HP ones in this guide.
Vincent - 답글 공유
I think this might be the stick: https://www.mouser.com/ProductDetail/Alp...
Alps RKJXV 23 degree 10K ohm multi-directional switches
I haven’t soldered it yet so do not take my word as fact, it just looks right.
Vincent - 답글 공유
I have one issue post doing this. I reaoldered everything. The multimeter doesn't read OL anywhere BUT the controller will not power on when reassembled.
Layrinn - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 27
전체 시간: 1,774
