주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Z2 Mini G3 Real-Time Clock Battery Replacement
    1. HP Z2 Mini G3 Real-Time Clock Battery Replacement, Access Panel: 1 단계, 이미지 1개 중 1개
      • Turn the device so the back-side of the device is facing you.
      • Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device or harm yourself.
      • Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
      댓글 쓰기
    2. HP Z2 Mini G3 Real-Time Clock Battery Replacement: 2 단계, 이미지 2개 중 1개 HP Z2 Mini G3 Real-Time Clock Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Slide and hold the latch in the direction of the engraved arrow (to the right).
      댓글 쓰기
    3. HP Z2 Mini G3 Real-Time Clock Battery Replacement: 3 단계, 이미지 2개 중 1개 HP Z2 Mini G3 Real-Time Clock Battery Replacement: 3 단계, 이미지 2개 중 2개
      • While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
      댓글 쓰기
    1. HP Z2 Mini G3 Real-Time Clock Battery Replacement, Real-Time Clock Battery: 4 단계, 이미지 1개 중 1개
      • Rotate the device so the back-side is facing you and locate the RTC battery.
      • You may have to swing the CPU Fan and GPU Fan upwards to fully access the Real-Time Clock (RTC) Battery.
      댓글 쓰기
    2. HP Z2 Mini G3 Real-Time Clock Battery Replacement: 5 단계, 이미지 1개 중 1개
      • Press the battery down and away to free it of the latches.
      • Use your hand to grab and lift the battery out of the socket.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 27
지난 30일: 120
전체 시간: 5,013
