주요 콘텐츠로 건너뛰기
HP m8226x Power Supply Replacement
Scott Fisher
Scott Fisher다른 한 명의 기여자
최종 수정일 May 18, 2016
20 분
쉬움
This guide will show you what needs to be removed and how to remove it in order to replace the power supply of the HP M8226x. When buying a new power supply, make sure it has both SATA port and 4-pin power connectors on it and has an output of at least 350W.
필요한 것
부품
도구
  1. HP m8226x Power Supply Replacement, HP m8226x Power Supply: 1 단계, 이미지 3개 중 1개 HP m8226x Power Supply Replacement, HP m8226x Power Supply: 1 단계, 이미지 3개 중 2개 HP m8226x Power Supply Replacement, HP m8226x Power Supply: 1 단계, 이미지 3개 중 3개
    • Turn off your computer and remove the power cord by pulling it straight out of its socket.
  2. HP m8226x Power Supply Replacement: 2 단계, 이미지 3개 중 1개 HP m8226x Power Supply Replacement: 2 단계, 이미지 3개 중 2개 HP m8226x Power Supply Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the two screws holding the right (from the back) case door to the computer.
  3. HP m8226x Power Supply Replacement: 3 단계, 이미지 3개 중 1개 HP m8226x Power Supply Replacement: 3 단계, 이미지 3개 중 2개 HP m8226x Power Supply Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the side case door by pulling the tab towards the back of the computer with your hand.
    • Pull the door outward to remove it.
  4. HP m8226x Power Supply Replacement: 4 단계, 이미지 2개 중 1개 HP m8226x Power Supply Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the four screws holding in the power supply.
  5. HP m8226x Power Supply Replacement: 5 단계, 이미지 1개 중 1개
    • Lay the computer on its side to make it easier to remove the wiring.
  6. HP m8226x Power Supply Replacement: 6 단계, 이미지 3개 중 1개 HP m8226x Power Supply Replacement: 6 단계, 이미지 3개 중 2개 HP m8226x Power Supply Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the computer processor's power cord by pinching the clip on the connector and pulling it straight out.
  7. HP m8226x Power Supply Replacement: 7 단계, 이미지 3개 중 1개 HP m8226x Power Supply Replacement: 7 단계, 이미지 3개 중 2개 HP m8226x Power Supply Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the power cord from the optical disc drive by pulling it straight out.
  8. HP m8226x Power Supply Replacement: 8 단계, 이미지 3개 중 1개 HP m8226x Power Supply Replacement: 8 단계, 이미지 3개 중 2개 HP m8226x Power Supply Replacement: 8 단계, 이미지 3개 중 3개
    • If the hard drive doesn't have a SATA port connector then move to step 9.
    • Disconnect the SATA port connector from the hard drive by pulling it straight out.
  9. HP m8226x Power Supply Replacement: 9 단계, 이미지 2개 중 1개 HP m8226x Power Supply Replacement: 9 단계, 이미지 2개 중 2개
    • If the hard drive has a 4-pin Molex connector, pinch the two clips on the connector and pull it straight out to remove it.
  10. HP m8226x Power Supply Replacement: 10 단계, 이미지 3개 중 1개 HP m8226x Power Supply Replacement: 10 단계, 이미지 3개 중 2개 HP m8226x Power Supply Replacement: 10 단계, 이미지 3개 중 3개
    • Remove the power to the motherboard by pinching the clip and pulling it straight out.
  11. HP m8226x Power Supply Replacement: 11 단계, 이미지 2개 중 1개 HP m8226x Power Supply Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the power supply by pushing it out from the back of the computer and lifting it out of the computer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Scott Fisher
회원 가입일: 03/30/16
128 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 11
전체 시간: 955
