HP rp5700 Hard Drive Replacement
The hard drive is the component that provides information storage for the computer. Use caution when handling the hard drive. Any type of shock to the drive could cause hard drive failure.
Make sure the computer is unplugged.
Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
Set the desktop down horizontally with the front side facing you.
Using your right hand, grip the CD drive and lift it up to a 90 degree position.
다른 8명이 해당 안내서를 완성하였습니다.
