주요 콘텐츠로 건너뛰기
HP-Pavillion 500-424 PC Series CPU Fan Replacement
Amanda Milby
Amanda Milby2 다른 기여자
최종 수정일 June 3, 2022
5 - 15 분
쉬움
If the CPU fan becomes to filled with dust or stops spinning, it must be replaced immediately. If it is not replaced then the CPU or motherboard can become damaged and cause the computer to be unbootable
  1. HP-Pavillion 500-424 PC Series CPU Fan Replacement, Central Processor Fan: 1 단계, 이미지 2개 중 1개 HP-Pavillion 500-424 PC Series CPU Fan Replacement, Central Processor Fan: 1 단계, 이미지 2개 중 2개
    • Lay the tower down carefully on its right side, with the vents pointing up.
  2. HP-Pavillion 500-424 PC Series CPU Fan Replacement: 2 단계, 이미지 3개 중 1개 HP-Pavillion 500-424 PC Series CPU Fan Replacement: 2 단계, 이미지 3개 중 2개 HP-Pavillion 500-424 PC Series CPU Fan Replacement: 2 단계, 이미지 3개 중 3개
    • Use the flat head #6 screwdriver bit to unscrew the tower casing.
    • Very gently slide the case towards you.
    • Lift the casing up and gently place it off to the side.
  3. HP-Pavillion 500-424 PC Series CPU Fan Replacement: 3 단계, 이미지 3개 중 1개 HP-Pavillion 500-424 PC Series CPU Fan Replacement: 3 단계, 이미지 3개 중 2개 HP-Pavillion 500-424 PC Series CPU Fan Replacement: 3 단계, 이미지 3개 중 3개
    • Unplug the fan from the motherboard by gently grasping the connector and slowing pulling up.
    • Remove each screw from the fan using the Phillips head screwdriver bit.
    • Place the screws in a cup, they are very small and can be lost easily.
    • Remove the old fan from the CPU.
결론
To reassemble your device, follow these instructions in reverse order. Now you should feel confident replacing the CPU fan in your HP desktop without any difficulties.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Amanda Milby
회원 가입일: 09/13/18
177 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 14
전체 시간: 2,129
