주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC Trophy Headphone Jack Replacement
필요한 것
    1. HTC Trophy Headphone Jack  Replacement, Battery: 1 단계, 이미지 3개 중 1개 HTC Trophy Headphone Jack  Replacement, Battery: 1 단계, 이미지 3개 중 2개 HTC Trophy Headphone Jack  Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • Power off the phone before starting.
      • Remove the back panel by inserting the IFixIt opening tool into gap at the top of the rear and prying upward.
      댓글 쓰기
    2. HTC Trophy Headphone Jack  Replacement: 2 단계, 이미지 3개 중 1개 HTC Trophy Headphone Jack  Replacement: 2 단계, 이미지 3개 중 2개 HTC Trophy Headphone Jack  Replacement: 2 단계, 이미지 3개 중 3개
      • Remove the battery by inserting the IFixIt opening tool into the small gap between the battery and the surrounding plastic.
      • Apply a small force towards the bottom of the phone and lift upwards.
      • Be careful not to puncture the battery.
      댓글 쓰기
    1. HTC Trophy Headphone Jack  Replacement, Display Assembly: 3 단계, 이미지 3개 중 1개 HTC Trophy Headphone Jack  Replacement, Display Assembly: 3 단계, 이미지 3개 중 2개 HTC Trophy Headphone Jack  Replacement, Display Assembly: 3 단계, 이미지 3개 중 3개
      • Remove the 5 screws holding the two phone halves together.
      • Three 4mm long T5 Torx screws.
      • Press a T5 Torx screwdriver into the void sticker and remove the 4mm long T5 Torx screw.
      • One 4mm long Philips #000 screw.
      • Remove the installed SIM card if one is present.
      댓글 쓰기
    2. HTC Trophy Headphone Jack  Replacement: 4 단계, 이미지 3개 중 1개 HTC Trophy Headphone Jack  Replacement: 4 단계, 이미지 3개 중 2개 HTC Trophy Headphone Jack  Replacement: 4 단계, 이미지 3개 중 3개
      • Insert the IFixIt opening tool into the seem of the plastic around the edge of the phone and pry the two halves apart.
      • There are small plastic clips holding the phone together. Slide the opening tool around the edge until it clicks apart to avoid damage.
      • The volume button will fall out when the phone is opened.
      • The black sticker beneath the battery will rip once the phone is separated.
      댓글 쓰기
    3. HTC Trophy Headphone Jack  Replacement: 5 단계, 이미지 3개 중 1개 HTC Trophy Headphone Jack  Replacement: 5 단계, 이미지 3개 중 2개 HTC Trophy Headphone Jack  Replacement: 5 단계, 이미지 3개 중 3개
      • Remove the three screws holding the mother board to the display assembly.
      • One 2mm long Philips #000 screw.
      • Two 4mm long T5 Torx screws in the holes of the plastic.
      댓글 쓰기
    4. HTC Trophy Headphone Jack  Replacement: 6 단계, 이미지 3개 중 1개 HTC Trophy Headphone Jack  Replacement: 6 단계, 이미지 3개 중 2개 HTC Trophy Headphone Jack  Replacement: 6 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Remove the black tape cover the ribbon cable connectors with tweezers.
      • Disconnect the ribbon cables from the connectors.
      • Ribbon cables are extremely fragile.
      댓글 쓰기
    5. HTC Trophy Headphone Jack  Replacement: 7 단계, 이미지 2개 중 1개 HTC Trophy Headphone Jack  Replacement: 7 단계, 이미지 2개 중 2개
      • Remove power button from the top of the phone with tweezers.
      댓글 쓰기
    6. HTC Trophy Headphone Jack  Replacement: 8 단계, 이미지 3개 중 1개 HTC Trophy Headphone Jack  Replacement: 8 단계, 이미지 3개 중 2개 HTC Trophy Headphone Jack  Replacement: 8 단계, 이미지 3개 중 3개
      • Use the iFixit opening tool to separate the motherboard from the display assembly.
      댓글 쓰기
    1. HTC Trophy Headphone Jack  Replacement, Motherboard: 9 단계, 이미지 3개 중 1개 HTC Trophy Headphone Jack  Replacement, Motherboard: 9 단계, 이미지 3개 중 2개 HTC Trophy Headphone Jack  Replacement, Motherboard: 9 단계, 이미지 3개 중 3개
      • Remove the plastic piece off of the motherboard.
      • Put pressure outwards to release these clips with the iFixit opening tool and you fingers.
      댓글 쓰기
    1. HTC Trophy Headphone Jack  Replacement, Headphone Jack: 10 단계, 이미지 2개 중 1개 HTC Trophy Headphone Jack  Replacement, Headphone Jack: 10 단계, 이미지 2개 중 2개
      • Desolder the headphone jack from the motherboard.
      • Be careful to not overheat other components on the motherboard.
      • For more information on soldering and desoldering connections, please read the How to Solder and Desolder Connections guide.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Victoria Schmidt
회원 가입일: 09/24/19
320 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 19
전체 시간: 350
