주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Headphone Plug Replacement
필요한 것
    1. Headphone Plug Replacement, Audio Jack: 1 단계, 이미지 2개 중 1개 Headphone Plug Replacement, Audio Jack: 1 단계, 이미지 2개 중 2개
      • Unscrew the casing from your replacement plug.
      댓글 쓰기
    2. Headphone Plug Replacement: 2 단계, 이미지 3개 중 1개 Headphone Plug Replacement: 2 단계, 이미지 3개 중 2개 Headphone Plug Replacement: 2 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Digital Multimeter
      $59.95
      • Using a multimeter (set in ohms to test resistance), test each terminal on the base of the plug to see which terminal corresponds to which speaker (left or right). You'll know they correspond when a value other than 1 appears on the multimeter.
      • Image 3 shows which part of the plug corresponds to each cable:
      • Left
      • Right
      • Common (or ground)
      • My results showed that the terminal with the larger hole corresponded to the right speaker, while the terminal with the smaller hole corresponded to the left speaker. Your results may differ.
      댓글 쓰기
    3. Headphone Plug Replacement: 3 단계, 이미지 2개 중 1개 Headphone Plug Replacement: 3 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      Flush Cutter
      $34.95
      • Using your wire cutter, remove the broken 3.5mm plug from the wire.
      댓글 쓰기
    4. Headphone Plug Replacement: 4 단계, 이미지 3개 중 1개 Headphone Plug Replacement: 4 단계, 이미지 3개 중 2개 Headphone Plug Replacement: 4 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Wire Stripper
      $34.95
      • Use your wire stripper to expose about 2cm of the the wire.
      • You must also remove the coating from each smaller, individual wire by using a wire stripper, fine sandpaper, or something of that sort.
      • If you attempt to solder the wires without removing the coating, the connection most likely will not work.
      댓글 쓰기
    5. Headphone Plug Replacement: 5 단계, 이미지 2개 중 1개 Headphone Plug Replacement: 5 단계, 이미지 2개 중 2개
      • Slide the casing (from Step 1) onto the wire.
      • You'll have to screw this back onto the plug at the end, so be sure it's facing the correct way.
      댓글 쓰기
    6. Headphone Plug Replacement: 6 단계, 이미지 3개 중 1개 Headphone Plug Replacement: 6 단계, 이미지 3개 중 2개 Headphone Plug Replacement: 6 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Helping Hands
      $9.99
      • Helping hands may be helpful when soldering. If you have never soldered before, check out this soldering technique guide.
      • Slide the red wire through the hole of the terminal that corresponds to the right speaker. Wrap the wire around the terminal a few times, then solder it in place.
      • Repeat this step for the terminal that corresponds to the left speaker. Note that the left audio wire is often white or green.
      • Finally, solder the common/ground wire (often copper colored) and any multicolored wires through the remaining hole.
      • The pictures show a blue wire and several yellow wires. The blue wire was soldered with the ground wire, and the yellow wires turned out simply to be nylon (not actual wires).
      댓글 쓰기
    7. Headphone Plug Replacement: 7 단계, 이미지 1개 중 1개
      • To finish, screw the casing back onto the plug.
      • Be sure the two terminals (or connecting wires) do not touch each other; if they touch, the fix will not work properly.
      댓글 쓰기
결론
If the fix did not work, make sure the wires are in direct contact with the terminals. Also make sure that they are not in contact with each other. If done correctly, your trusty pair of earphones (or headphones) can be trusted for quite a while longer!
취소: 해당 안내서를 완성하지 않았습니다.
다른 27명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Andrew Yoder
회원 가입일: 04/09/15
1,141 평판
안내서 1개를 작성함
Cal Poly, Team 28-4, Green Spring 2015 Cal Poly, Team 28-4, Green Spring 2015 회원
CPSU-GREEN-S15S28G4
6 회원들
안내서 25개를 작성함
2가이드 댓글
The first sentence in your introduction can maybe be changed to: "Often times one earpiece of the earphones stop working."
Your description is well-written and thoroughly describes the process. I would just add pictures specifically pointing to the different parts you mention in your steps.
Otherwise it's all good! :)
Salonee - 답글 공유
Is there a special fix for earphones with a control unit embedded?
Marcel Alani - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 57
지난 30일: 260
전체 시간: 63,244
