Homedics UHE-CMP15 Battery Replacement
15 분 - 1 시간
어려움
If you believe the battery in your device may be faulty, follow this guide to access the battery compartment. For this guide, you will need a thin Phillip's head screwdriver, tweezers, and a soldering iron once you get to the battery itself.
필요한 것
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
Make sure your device is turned off by pressing the power button and ensuring the LED lights are off.
Unscrew top from the container by twisting the top of the container counter clockwise and pulling up.
거의 끝나갑니다!
결론
