주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Honeywell HT900C Motor Replacement
Duy  Anh Nguyen
Duy Anh Nguyen다른 한 명의 기여자
최종 수정일 2022년 12월 28일
10 - 15 분
조정
There are a number of potential causes if your Honeywell HT900C fan does not start when you turn it on, including the fan motor being damaged from overuse, the fan being misaligned, etc. The fan motor is the most common culprit because it drives the rest of the fan. Our instructions will guide you through disassembling the old motor and installing the new one. All that is required is a screwdriver and some lubricant, both of which can be found in almost every home.
필요한 것
도구
  1. Honeywell HT900C Motor Replacement, Motor: 1 단계, 이미지 3개 중 1개 Honeywell HT900C Motor Replacement, Motor: 1 단계, 이미지 3개 중 2개 Honeywell HT900C Motor Replacement, Motor: 1 단계, 이미지 3개 중 3개
    • Remove the six 15 mm screws securing the fan's frame to its outer ring on the back using a Phillips #1 screwdriver.
    • Due to the small size of the screw holes, a long and thin screwdriver may be necessary.
  2. Honeywell HT900C Motor Replacement: 2 단계, 이미지 3개 중 1개 Honeywell HT900C Motor Replacement: 2 단계, 이미지 3개 중 2개 Honeywell HT900C Motor Replacement: 2 단계, 이미지 3개 중 3개
    • To gain access to the fan's inner workings, gently pull the blade cover away from the main body.
  3. Honeywell HT900C Motor Replacement: 3 단계, 이미지 2개 중 1개 Honeywell HT900C Motor Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the two 36 mm screws from the metal plate located behind the blades using a Phillips #1 screwdriver.
    • The screws can be hard to remove so you may need to twist the screwdriver harder and screws can be removed easily.
  4. Honeywell HT900C Motor Replacement: 4 단계, 이미지 3개 중 1개 Honeywell HT900C Motor Replacement: 4 단계, 이미지 3개 중 2개 Honeywell HT900C Motor Replacement: 4 단계, 이미지 3개 중 3개
    • Carefully pull the motor it out of its resting position and tilt it forward to access the back of the motor.
  5. Honeywell HT900C Motor Replacement: 5 단계, 이미지 3개 중 1개 Honeywell HT900C Motor Replacement: 5 단계, 이미지 3개 중 2개 Honeywell HT900C Motor Replacement: 5 단계, 이미지 3개 중 3개
    • Remove two 10 mm screws from the motor's back using a Phillips #1 screwdriver.
  6. Honeywell HT900C Motor Replacement: 6 단계, 이미지 2개 중 1개 Honeywell HT900C Motor Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the 20 mm screws beside the fan blade using a Phillips #1 screwdriver.
    • The screws are attached to two parts of the motor so it can easily fall off after removing the screws.
  7. Honeywell HT900C Motor Replacement: 7 단계, 이미지 1개 중 1개
    • Carefully remove the circular motor from the square holder.
    • The circular motor is still connected to the fan blades.
  8. Honeywell HT900C Motor Replacement: 8 단계, 이미지 2개 중 1개 Honeywell HT900C Motor Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the metal washer from the axle.
  9. Honeywell HT900C Motor Replacement: 9 단계, 이미지 1개 중 1개
    • Replace the old motor with a new one, and you're done!
    • Using the lubricant to easily put the new motor back.
    • Always double-check that the screws are securely in place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
향후 수리를 위한 준비
모두 쇼핑하기
작성자
1다른 기여자 명과 함께
Duy Anh Nguyen
회원 가입일: 09/17/22
169 평판
안내서 1개를 작성함
York University, Team B-10, Allen Fall 2022 York University, Team B-10, Allen Fall 2022 회원
YORK-ALLEN-F22SBG10
3 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 35
전체 시간: 1,321
