주요 콘텐츠로 건너뛰기
Honeywell HY-204 Rotation Button Replacement
Nolan Ernotte
Nolan Ernotte4 다른 기여자
최종 수정일 September 3, 2019
15 - 20 분
어려움
This guide shows how to replace the rotation button that controls the oscillation of your fan. Replacing the rotation button requires soldering, so it may be a little tricky for those of you who are inexperienced with soldering.
필요한 것
도구
더보기...
  1. Honeywell HY-204 Rotation Button Replacement, Case: 1 단계, 이미지 2개 중 1개 Honeywell HY-204 Rotation Button Replacement, Case: 1 단계, 이미지 2개 중 2개
    • Before you begin, be sure to unplug the fan.
    • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
  2. Honeywell HY-204 Rotation Button Replacement: 2 단계, 이미지 2개 중 1개 Honeywell HY-204 Rotation Button Replacement: 2 단계, 이미지 2개 중 2개
    • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
  3. Honeywell HY-204 Rotation Button Replacement, Control Panel: 3 단계, 이미지 2개 중 1개 Honeywell HY-204 Rotation Button Replacement, Control Panel: 3 단계, 이미지 2개 중 2개
    • Remove the two 3mm screws found just below the top of the device using the Phillips #0 Screwdriver.
  4. Honeywell HY-204 Rotation Button Replacement: 4 단계, 이미지 1개 중 1개
    • Pry off the control panel by forcefully lifting the tab located inside the front of the fan with the plastic opening tool.
  5. Honeywell HY-204 Rotation Button Replacement, Rotation Button: 5 단계, 이미지 2개 중 1개 Honeywell HY-204 Rotation Button Replacement, Rotation Button: 5 단계, 이미지 2개 중 2개
    • Remove the two 10mm Phillips #0 screws that are located next to the rotation button.
  6. Honeywell HY-204 Rotation Button Replacement: 6 단계, 이미지 1개 중 1개
    • Peel back the heat shrink tubing on both wires connecting to the button.
  7. Honeywell HY-204 Rotation Button Replacement: 7 단계, 이미지 1개 중 1개
    • Caution The soldering iron is very hot, be careful to avoid burns.
    • Desolder the two wires connected to the button and remove the button.
결론
작성자
4다른 기여자 명과 함께
Nolan Ernotte
회원 가입일: 10/14/14
384 평판
안내서 3개를 작성함
Cal Poly, Team 10-40, Amido Fall 2014 Cal Poly, Team 10-40, Amido Fall 2014 회원
CPSU-AMIDO-F14S10G40
3 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 994
