Honeywell HY-254-TGT Front Panel Replacement
Follow this guide to remove or repair any of the parts related to the front panel.
필요한 것
Remove the two 3/4" wing screws on the bottom of the fan by rotating them counter-clockwise.
Remove the four 1/2" Phillips #02 screws, indicated by a red circle.
Lean the front panel forwards and set it down.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
the piece to make it turn is broken
the piece that make it turn is broken!
