주요 콘텐츠로 건너뛰기
Honeywell Quietset HY5260BC Fan Blades Replacement
fabiha tarannum
fabiha tarannum6 다른 기여자
최종 수정일 June 13, 2024
55 분 - 1 시간
조정
더 나은 이미지가 필요함
This guide will show a step-by-step process of how to remove and replace your old, broken, or dirty fan blades. It will also provide some tips to stop your fan from making rattling noises.
Safety Tips:
  • Unplug your fan– you should never attempt to clean a fan while it’s plugged in.
  • It is highly recommended to wear a mask and/or protective eyewear to protect yourself from dust.
  • Make sure not to drop any of the lubricant greases in the ball bearing.
This process only applies to traditional tower fans. Therefore, if you have a blade-less fan, the process will vary.
Good luck!
필요한 것
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. Honeywell Quietset HY5260BC Fan Blades Replacement, Fan Blades: 1 단계, 이미지 1개 중 1개
    • To avoid risk of electrocution, unplug the fan from the power outlet.
    • Lay the fan horizontally and remove the base by unscrewing the locking nut from the fan housing.
  2. Honeywell Quietset HY5260BC Fan Blades Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the 3” wing screw on the bottom of the fan; then, remove the four 3" screws on the top of the fan.
    • A Torx screwdriver is required for this process.
  3. Honeywell Quietset HY5260BC Fan Blades Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully open up the fan housing in half by pulling the front and back parts away from each other. You should now be able to see the motor attached with the fan blade.
    • This may require a large amount of force, so proceed with caution. You may use a plastic tool to separate the parts.
  4. Honeywell Quietset HY5260BC Fan Blades Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the screw connecting the motor shaft with the bottom half of the fan blade.
  5. Honeywell Quietset HY5260BC Fan Blades Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the two screws connecting the metal bracket with the fan blade and remove the metal bracket.
  6. Honeywell Quietset HY5260BC Fan Blades Replacement: 6 단계, 이미지 1개 중 1개
    • To carefully remove the fan blades, grab the fan blades firmly and lift them toward yourself.
    • Gently clean the inner surface of the fan with a cloth or a vacuum cleaner to remove all the dust that has collected through usage.
  7. Honeywell Quietset HY5260BC Fan Blades Replacement: 7 단계, 이미지 1개 중 1개
    • To fix the rattling noise, carefully apply lubricating grease around the blade drum’s shaft.
    • Make sure not to drop any of the lubricants onto the bearing!
  8. Honeywell Quietset HY5260BC Fan Blades Replacement: 8 단계, 이미지 1개 중 1개
    • Lubricate the metal bracket’s tab and around the screw holes.
    • To avoid a future squeaky noise, put a liquid rubber on the top surface during reassembly. This effectively prevents friction.
  9. Honeywell Quietset HY5260BC Fan Blades Replacement: 9 단계, 이미지 1개 중 1개
    • Slowly place the new fan blades in correct alignment.
    • The slots on the fan blades and centre column must be aligned perfectly.
  10. Honeywell Quietset HY5260BC Fan Blades Replacement: 10 단계, 이미지 1개 중 1개
    • To stop the new fan blades from vibrating, tighten the screws around the metal bracket and motor shaft. Then, place the other half of the tower casing and screw it in place.
    • It is important to connect and adjust all parts of the tower fan securely in place to avoid noise.
결론
To reassemble your device, follow these instructions in reverse order. Follow this guide to self-service your tower fan yourself saving lots of money!
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
fabiha tarannum
회원 가입일: 01/21/21
202 평판
안내서 1개를 작성함
댓글 한 개
Where can I buy the fan blades
Dan Man - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 33
전체 시간: 4,832
