Hoover LiNX Wheel Replacement
20 분
조정
This guide will show you how to replace the wheels of your device. This would be needed if your device fails to roll on the flooring or if they simply broke apart. Be sure to remove the battery from the device and switch the power off.
Detach the rolling assembly from the body by pushing the button found at the base.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
