주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hover-1 Charger Battery Replacement
필요한 것
    1. Hover-1 Charger Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Hover-1 Charger Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Flip the hoverboard over so that the warning label is facing up.
      • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
      • Remove the four 10 mm screws with a Phillips #2 screwdriver.
      • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
      댓글 쓰기
    2. Hover-1 Charger Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Pull the right cover away from the hoverboard to expose the battery.
      댓글 쓰기
    3. Hover-1 Charger Battery Replacement: 3 단계, 이미지 2개 중 1개 Hover-1 Charger Battery Replacement: 3 단계, 이미지 2개 중 2개
      • Unplug the battery by disconnecting the two pronged black and yellow cable.
      댓글 쓰기
    4. Hover-1 Charger Battery Replacement: 4 단계, 이미지 1개 중 1개
      • Pull the left cover away from the hoverboard.
      댓글 쓰기
    5. Hover-1 Charger Battery Replacement: 5 단계, 이미지 2개 중 1개 Hover-1 Charger Battery Replacement: 5 단계, 이미지 2개 중 2개
      • Disconnect the two pronged black and yellow cable.
      • Thread the cable through the middle cylinder of the hoverboard.
      댓글 쓰기
    6. Hover-1 Charger Battery Replacement: 6 단계, 이미지 2개 중 1개 Hover-1 Charger Battery Replacement: 6 단계, 이미지 2개 중 2개
      • Unscrew the four 10mm screws that are holding the battery casing in place. Use a Phillips #2 screwdriver.
      • If there is a zip-tie connecting the wires together, carefully cut it with a wire cutters.
      댓글 쓰기
    7. Hover-1 Charger Battery Replacement: 7 단계, 이미지 3개 중 1개 Hover-1 Charger Battery Replacement: 7 단계, 이미지 3개 중 2개 Hover-1 Charger Battery Replacement: 7 단계, 이미지 3개 중 3개
      • On the battery side, unplug the white five pin connector on the circuitboard.
      • Unplug the black, yellow, green and red connector on the circuitboard.
      댓글 쓰기
    8. Hover-1 Charger Battery Replacement: 8 단계, 이미지 1개 중 1개
      • Move all the loose cables to the side. Pull the battery casing away from the battery.
      댓글 쓰기
    9. Hover-1 Charger Battery Replacement: 9 단계, 이미지 1개 중 1개
      • Use the opening tool to remove the battery from the metal casing.
      • The battery is stuck to the metal casing with strong adhesive; do not be afraid to apply a strong force with the opening tool.
      댓글 쓰기
    10. Hover-1 Charger Battery Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the battery.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Melanie Hardell
회원 가입일: 10/10/19
517 평판
안내서 2개를 작성함
Cal Poly, Team S12-G1, Regan Fall 2019 Cal Poly, Team S12-G1, Regan Fall 2019 회원
CPSU-REGAN-F19S12G1
4 회원들
안내서 6개를 작성함
1가이드 댓글
Can I replace my battery 25.2v to a 36v.
Airie Green - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 19
지난 30일: 82
전체 시간: 10,569
