주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hover-1 Charger Gyroscope Sensor Board Replacement
필요한 것
    1. Hover-1 Charger Gyroscope Sensor Board Replacement, Unplugging the Battery: 1 단계, 이미지 2개 중 1개 Hover-1 Charger Gyroscope Sensor Board Replacement, Unplugging the Battery: 1 단계, 이미지 2개 중 2개
      • Flip the hoverboard over so that the warning label is facing up.
      • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
      • Remove the four 10 mm screws with a Phillips #2 screwdriver.
      • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
      댓글 쓰기
    2. Hover-1 Charger Gyroscope Sensor Board Replacement: 2 단계, 이미지 1개 중 1개
      • Pull the right cover away from the hoverboard to expose the battery.
      댓글 쓰기
    3. Hover-1 Charger Gyroscope Sensor Board Replacement: 3 단계, 이미지 2개 중 1개 Hover-1 Charger Gyroscope Sensor Board Replacement: 3 단계, 이미지 2개 중 2개
      • Disconnect the two pronged black and yellow cable.
      댓글 쓰기
    4. Hover-1 Charger Gyroscope Sensor Board Replacement: 4 단계, 이미지 1개 중 1개
      • Pull the left cover away from the hoverboard.
      댓글 쓰기
    5. Hover-1 Charger Gyroscope Sensor Board Replacement: 5 단계, 이미지 2개 중 1개 Hover-1 Charger Gyroscope Sensor Board Replacement: 5 단계, 이미지 2개 중 2개
      • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
      댓글 쓰기
    1. Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: 6 단계, 이미지 3개 중 1개 Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: 6 단계, 이미지 3개 중 2개 Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: 6 단계, 이미지 3개 중 3개
      • Unplug the white five pin connector from the gyroscope sensor board.
      • Unplug the red, yellow, blue, green, black and white six pin connector.
      • Unplug the black and red two pin connector.
      • Unplug the black, yellow, green and red four pin connector. Unplugging this connector is photographed as an example.
      댓글 쓰기
    2. Hover-1 Charger Gyroscope Sensor Board Replacement: 7 단계, 이미지 2개 중 1개 Hover-1 Charger Gyroscope Sensor Board Replacement: 7 단계, 이미지 2개 중 2개
      • Remove the four 10 mm screws from the gyroscope sensor board with a Phillips #2 screwdriver.
      댓글 쓰기
    3. Hover-1 Charger Gyroscope Sensor Board Replacement: 8 단계, 이미지 3개 중 1개 Hover-1 Charger Gyroscope Sensor Board Replacement: 8 단계, 이미지 3개 중 2개 Hover-1 Charger Gyroscope Sensor Board Replacement: 8 단계, 이미지 3개 중 3개
      • Push the rubber sheaths away from the clasp of the green bullet connector.
      • Grasp the connector at the metal junction and disconnect.
      • Repeat for the yellow and red bullet connectors.
      • There may be a zip tie holding these wires together. Cut this off.
      • These bullet connectors may be hard to disconnect; do not be afraid to pull with strong force.
      댓글 쓰기
    4. Hover-1 Charger Gyroscope Sensor Board Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the gyroscope sensor board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Melanie Hardell
회원 가입일: 10/10/19
517 평판
안내서 2개를 작성함
Cal Poly, Team S12-G1, Regan Fall 2019 Cal Poly, Team S12-G1, Regan Fall 2019 회원
CPSU-REGAN-F19S12G1
4 회원들
안내서 6개를 작성함
5가이드 댓글
Hi Where can I find the replacement sensor board? Thanks!
Jason LaDuke - 답글 공유
where do i find the replacement sensor board?
one wheel of my board doesn’t work
Philip Donkoh - 답글 공유
I need one of these replacement gyros please how I get
Matthew Isaiah Cowart - 답글 공유
Worthless guide. No instructions on where to get the replacement gyro boards
Fuckaboi - 답글 공유
this is a joke. 2 years still not one kind enough soul to help find where to purchase replacements!!!!!!!!
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 36
전체 시간: 6,114
