주요 콘텐츠로 건너뛰기
How To Fix Misaligned Bicycle Handlebars
Telmuun
Telmuun3 다른 기여자
최종 수정일 April 12, 2022
5 - 10 분
쉬움
더 많은 이미지가 필요함
Bicycle safety is key to a safe and enjoyable trip no matter where or how far. One of the most crucial safety features is handlebar alignment. Most riders don’t notice even the slightest unalignment until something unexpected happens. To prevent any potential safety hazards, I encourage you to check your bike's handle bars every time you ride.
For this project you will need an Allen wrench or hex key.
필요한 것
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. How To Fix Misaligned Bicycle Handlebars, How To Fix Misaligned Bicycle Handlebars: 1 단계, 이미지 2개 중 1개 How To Fix Misaligned Bicycle Handlebars, How To Fix Misaligned Bicycle Handlebars: 1 단계, 이미지 2개 중 2개
    • Stand with your bicycle in front of you.
    • Put your front wheel between your legs.
  2. How To Fix Misaligned Bicycle Handlebars: 2 단계, 이미지 1개 중 1개
    • Hold the bike's front wheel tight with your legs to keep the bike upright.
    • Grab the handlebar and make it perpendicular to the front wheel.
    • Keep your bike stable at all times.
  3. How To Fix Misaligned Bicycle Handlebars: 3 단계, 이미지 3개 중 1개 How To Fix Misaligned Bicycle Handlebars: 3 단계, 이미지 3개 중 2개 How To Fix Misaligned Bicycle Handlebars: 3 단계, 이미지 3개 중 3개
    • Loosen the stem using the Allen wrench. Do minor adjustments using your hand.
    • Put the handlebar in a straight position. Then use a ruler, tape measure, or adjust by sight to the correct placement.
  4. How To Fix Misaligned Bicycle Handlebars: 4 단계, 이미지 2개 중 1개 How To Fix Misaligned Bicycle Handlebars: 4 단계, 이미지 2개 중 2개
    • DO NOT move your handle bars when you are adjusting the position.
    • Use the Allen wrench or Hex key to gently turn the two bolts (some bikes have one) on the stem until they hold tight.
  5. How To Fix Misaligned Bicycle Handlebars: 5 단계, 이미지 1개 중 1개
    • After tightening the bolt(s), check the alignment again.
    • Now, try rotating your bike using handlebar.
    • If it's still loose that means you may need to replace the handlebar.
  6. How To Fix Misaligned Bicycle Handlebars: 6 단계, 이미지 1개 중 1개
    • If your handlebar works as expected you can ride your bike now.
    • Have a safe trip!
결론
Using this guide will help you easily fix your handlebar.
첨부 문서
작성자
3다른 기여자 명과 함께
Telmuun
회원 가입일: 09/07/21
133 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 45
지난 30일: 101
전체 시간: 16,172
