주요 콘텐츠로 건너뛰기
How to Attach Googly Eyes to the Anti-Clamp
필요한 것
  1. How to Attach Googly Eyes to the Anti-Clamp, Clean Clampy: 1 단계, 이미지 2개 중 1개 How to Attach Googly Eyes to the Anti-Clamp, Clean Clampy: 1 단계, 이미지 2개 중 2개
    • Before you begin, wipe down Clampy to ensure a clean surface for the googly eyes to adhere to.
  2. How to Attach Googly Eyes to the Anti-Clamp, Peel off the liner: 2 단계, 이미지 2개 중 1개 How to Attach Googly Eyes to the Anti-Clamp, Peel off the liner: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers, or your fingers, to peel off the paper liner and expose the googly eye's adhesive.
    • Repeat the previous two steps for Clampy's second eye (unless you want a Cyclops Clampy).
  3. How to Attach Googly Eyes to the Anti-Clamp, Peel off the adhesive: 3 단계, 이미지 3개 중 1개 How to Attach Googly Eyes to the Anti-Clamp, Peel off the adhesive: 3 단계, 이미지 3개 중 2개 How to Attach Googly Eyes to the Anti-Clamp, Peel off the adhesive: 3 단계, 이미지 3개 중 3개
    • If you want to use alternate adhesive, follow the next three steps. Otherwise, skip to this step.
    • Use tweezers to peel off a portion of pre-cut adhesive.
    • It doesn't have to be a lot of adhesive—just enough to allow the googly eye to stick securely.
    • You can also use double-sided tape instead of pre-cut adhesive. Clampy isn't picky.
  4. How to Attach Googly Eyes to the Anti-Clamp, Apply the adhesive to the eye: 4 단계, 이미지 3개 중 1개 How to Attach Googly Eyes to the Anti-Clamp, Apply the adhesive to the eye: 4 단계, 이미지 3개 중 2개 How to Attach Googly Eyes to the Anti-Clamp, Apply the adhesive to the eye: 4 단계, 이미지 3개 중 3개
    • Place the sticky side of the adhesive on the back of a googly eye.
    • Press down on the adhesive to ensure it's fully adhered to the eye.
  5. How to Attach Googly Eyes to the Anti-Clamp, Peel off the liner: 5 단계, 이미지 3개 중 1개 How to Attach Googly Eyes to the Anti-Clamp, Peel off the liner: 5 단계, 이미지 3개 중 2개 How to Attach Googly Eyes to the Anti-Clamp, Peel off the liner: 5 단계, 이미지 3개 중 3개
    • Peel off the remaining liner to expose the adhesive.
    • Repeat the previous three steps for Clampy's second eye.
    • The only thing limiting the amount of eyes Clampy can have is your imagination.
  6. How to Attach Googly Eyes to the Anti-Clamp, Apply the eyes: 6 단계, 이미지 3개 중 1개 How to Attach Googly Eyes to the Anti-Clamp, Apply the eyes: 6 단계, 이미지 3개 중 2개 How to Attach Googly Eyes to the Anti-Clamp, Apply the eyes: 6 단계, 이미지 3개 중 3개
    • You are about to perform the repair equivalent of ocular surgery! Proceed with caution and care for Clampy.
    • Place the googly eyes on the top arm of Clampy, just above the suction cups.
    • Press down on each eye to ensure they fully adhere to Clampy.
  7. How to Attach Googly Eyes to the Anti-Clamp, Alternative eye positions: 7 단계, 이미지 3개 중 1개 How to Attach Googly Eyes to the Anti-Clamp, Alternative eye positions: 7 단계, 이미지 3개 중 2개 How to Attach Googly Eyes to the Anti-Clamp, Alternative eye positions: 7 단계, 이미지 3개 중 3개
    • Depending on your Clampy's personality, you can position its eyes in various ways.
    • The following images are some examples of alternative Clampy styles:
    • Prey Clampy
    • Suction-Cup-For-Feet Clampy
    • Snail Clampy
  8. How to Attach Googly Eyes to the Anti-Clamp, Feed Clampy: 8 단계, 이미지 3개 중 1개 How to Attach Googly Eyes to the Anti-Clamp, Feed Clampy: 8 단계, 이미지 3개 중 2개 How to Attach Googly Eyes to the Anti-Clamp, Feed Clampy: 8 단계, 이미지 3개 중 3개
    • Congratulations, you have given Clampy the gift of sight! However, it will now hunger for devices to open.
    • Give your Clampy something modest to open, like an iPhone 13 mini.
    • Make sure to remove the two P2 Pentalobe screws from the iPhone before giving it to Clampy.
  9. How to Attach Googly Eyes to the Anti-Clamp: 9 단계, 이미지 1개 중 1개
    • Watch Clampy open the device like a pro.
    • If your Clampy isn't sated, follow the next step.
  10. How to Attach Googly Eyes to the Anti-Clamp: 10 단계, 이미지 1개 중 1개
    • Give your Clampy something larger, like an iPhone 13 Pro.
    • Watch Clampy open this device with ease.
    • If your Clampy seems to open this device even faster...almost like its appetite is growing, follow the next step.
  11. How to Attach Googly Eyes to the Anti-Clamp: 11 단계, 이미지 1개 중 1개
    • Give your Clampy something monstrous, like an iPhone 13 Pro Max.
    • Watch Clampy lose control of itself and tear open the phone with unnecessary violence.
    • If you've run out of options, follow the next step.
  12. How to Attach Googly Eyes to the Anti-Clamp, Witness Clampy: 12 단계, 이미지 3개 중 1개 How to Attach Googly Eyes to the Anti-Clamp, Witness Clampy: 12 단계, 이미지 3개 중 2개 How to Attach Googly Eyes to the Anti-Clamp, Witness Clampy: 12 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Clampy - Anti-Clamp
    $24.95
    • Witness Clampy sit atop his pile of victims, each a testimony to his power of suction.
    • Legends tell of a clamp so powerful that even iPads shiver when they hear its name. Mothers all over the world tell their children that if they use too much adhesive on their electronics, a certain clamp will visit you in the night—and that clamp will show no mercy. These are only tales, however.
    • But, perhaps you've invoked this clamp-like being by attaching googly eyes to the Anti-Clamp. And that being's name is...
    • Clampy
결론
To send Clampy back to the realm of repair gods, follow the instructions in reverse order.
다른 40명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
214,971 평판
안내서 1,046개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,779개를 작성함
5가이드 댓글
I love this♥️💙💜💛🖤💚🧡🤍🤎
This is AMAZING!!!!!!
HelloMacOS - 답글
Clampy is hungry.
HeyItzRare - 답글
I love this website so much XD
MeowMix64 - 답글
My little clamps killed several friends of apple, and I rewarded it of course!
Ben Capehart - 답글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 40
지난 30일: 171
전체 시간: 5,737
