주요 콘텐츠로 건너뛰기
How to Detach the Keyboard on a Surface Book
필요한 것
  1. How to Detach the Keyboard on a Surface Book, Remove the display with the Detach button: 1 단계, 이미지 3개 중 1개 How to Detach the Keyboard on a Surface Book, Remove the display with the Detach button: 1 단계, 이미지 3개 중 2개 How to Detach the Keyboard on a Surface Book, Remove the display with the Detach button: 1 단계, 이미지 3개 중 3개
    • In order for the keyboard to be detached with the Detach buttons, both batteries must be charged above 10 percent. If your device doesn't power on and you can't use the Detach buttons, skip to the next step.
    • Press and hold the Detach button on the keyboard.
    • Once pressed, the Detach button it will light up red. After a second, it’ll turn green and you’ll hear an audible clicking sound.
    • Alternatively, click the Detach icon on the right-hand side of the Windows 10 taskbar.
    • Remove the display.
  2. How to Detach the Keyboard on a Surface Book, Manually detach the display: 2 단계, 이미지 2개 중 1개 How to Detach the Keyboard on a Surface Book, Manually detach the display: 2 단계, 이미지 2개 중 2개
    • The next six steps show how to detach the display manually if you’re unable to power on the Surface Book.
    • Flip open the display as far as it will go.
    • Lift the device up and place it on its side, with the display facing away from you and the SurfaceConnect port facing up.
  3. How to Detach the Keyboard on a Surface Book, Bend a paper clip: 3 단계, 이미지 2개 중 1개 How to Detach the Keyboard on a Surface Book, Bend a paper clip: 3 단계, 이미지 2개 중 2개
    • Straighten out one section of a paper clip.
  4. How to Detach the Keyboard on a Surface Book, Push the paper clip into the hole: 4 단계, 이미지 3개 중 1개 How to Detach the Keyboard on a Surface Book, Push the paper clip into the hole: 4 단계, 이미지 3개 중 2개 How to Detach the Keyboard on a Surface Book, Push the paper clip into the hole: 4 단계, 이미지 3개 중 3개
    • The Surface Book has an internal lever arm mechanism that can be manually actuated through an access hole in the vents on side of the display.
    • Insert the straight end of the paper clip at a 45 degree angle into the sixth hole from the left.
  5. How to Detach the Keyboard on a Surface Book, Release the mechanism: 5 단계, 이미지 3개 중 1개 How to Detach the Keyboard on a Surface Book, Release the mechanism: 5 단계, 이미지 3개 중 2개 How to Detach the Keyboard on a Surface Book, Release the mechanism: 5 단계, 이미지 3개 중 3개
    • Firmly push the paper clip into the hole.
    • This may take a considerable amount of force.
    • Once the internal lever arm is fully depressed, you can disconnect the display.
    • Pull the base away from the display to detach it.
    • If you are unable to detach the display from the base on this side, release pressure on the paper clip and try again.
  6. How to Detach the Keyboard on a Surface Book, Detach the second side: 6 단계, 이미지 3개 중 1개 How to Detach the Keyboard on a Surface Book, Detach the second side: 6 단계, 이미지 3개 중 2개 How to Detach the Keyboard on a Surface Book, Detach the second side: 6 단계, 이미지 3개 중 3개
    • The magnetic connections are prone to snap back into place, so hold the two halves apart.
    • With one side detached, pull firmly to pivot the display out to disconnect the second side.
    • If the magnetic connection feels extra strong and the display won't detach on the second side, keep the detached side separated with a spudger, pen, or pencil, and repeat the paper clip process on the other side of the display.
  7. How to Detach the Keyboard on a Surface Book, Remove the display: 7 단계, 이미지 1개 중 1개
    • Completely power down your Surface Book before opening it up for any repairs.
결론
To reattach the display, align the magnetic connectors and allow it to snap into place.
Procedure didn’t go as planned? Check out our Answers community for troubleshooting help.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Carsten Frauenheim
회원 가입일: 03/10/20
155,622 평판
안내서 439개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,648개를 작성함
7가이드 댓글
Hello,
Thank you for this tutorial.
Do you know if it works also for the latest Surface Book 3 in 15 inches size?
Philippe - 답글
merci beaucoup ce tutoriel m'a été très utile
Frank Pharose - 답글
Merci beaucoup pour ce partage, très utile!
Excellent travail!
bemba98 - 답글
These instructions are clear and concise - Worked perfectly! 5 stars out of 5! Thanks!
Caren Galloway - 답글
댓글 쓰기
조회 통계:
지난 24시간: 28
지난 7일: 203
지난 30일: 1,000
전체 시간: 95,477
