주요 콘텐츠로 건너뛰기
How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case
Abdul Haseeb Sajid
Abdul Haseeb Sajid다른 한 명의 기여자
최종 수정일 August 15, 2024
10 - 15 분
쉬움
If your COMFORTMATE FJYPD16H2 fan blade case is wobbling or moves when you pick the fan up, use this guide to repair it.
The blade case is the part around the fan blade and is there to protect you from the fast spinning blade.
Be careful of any broken parts as the edges of the plastic are sharp enough to cut skin.
You will need a piece of cloth or a paper towel to protect you when handling the fan blade in steps 4 and 10; safety gloves will also work.
필요한 것
도구
  1. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case, How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 1 단계, 이미지 1개 중 1개
    • Disconnect the fan from the power source.
  2. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 2 단계, 이미지 1개 중 1개
    • Locate the locking mechanism.
  3. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 3 단계, 이미지 2개 중 1개 How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 3 단계, 이미지 2개 중 2개
    • Pull the locking mechanism back and turn the front of the fan case counter clockwise and pull it off.
  4. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 4 단계, 이미지 3개 중 1개 How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 4 단계, 이미지 3개 중 2개 How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 4 단계, 이미지 3개 중 3개
    • While holding the fan blade in place using a piece of cloth or a paper towel, remove the spinner by turning it clockwise.
    • The blades are sharp and can cause cuts.
  5. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 5 단계, 이미지 2개 중 1개 How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 5 단계, 이미지 2개 중 2개
    • Pull the fan blade off and check for damage.
  6. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 6 단계, 이미지 1개 중 1개
    • Remove the plastic nut on the back of the fan case by turning it counter clockwise and check for damage.
  7. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 7 단계, 이미지 3개 중 1개 How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 7 단계, 이미지 3개 중 2개 How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 7 단계, 이미지 3개 중 3개
    • Make sure the holes on the back of the blade case are lined up with the protruding parts on the motorhead and is as far back as possible.
  8. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 8 단계, 이미지 2개 중 1개 How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 8 단계, 이미지 2개 중 2개
    • While holding the blade case in place attach the plastic nut by turning it clockwise.
  9. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 9 단계, 이미지 2개 중 1개 How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 9 단계, 이미지 2개 중 2개
    • Attach the fan blade back.
  10. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 10 단계, 이미지 1개 중 1개
    • While holding the fan blade in place using a piece of cloth or a paper towel, attach the spinner by turning it counter clockwise.
  11. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: 11 단계, 이미지 1개 중 1개
    • Attach the front of the blade case.
결승점
작성자
1다른 기여자 명과 함께
Abdul Haseeb Sajid
회원 가입일: 07/04/24
193 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 100
