주요 콘텐츠로 건너뛰기
How to Read Your Tire Size
Chaya Milchtein
Chaya Milchtein다른 한 명의 기여자
최종 수정일 December 11, 2024
예상시간 없음
매우 쉬움
커뮤니티-기여 안내서
Understanding the numbers that make up your tire size can help with buying tires.
    • Your tire size will be listed on the side of your tire and will read something like this: P225/50R16.
    • You can also find the original tire size for your car on a sticker inside the driver's side door and in your owner's manual.
    • The first letter, in front of the numbers (in this case, P) indicates the type of tire. Typically you'll see P for passenger or LT for light truck tires (common on SUVs and Pickups)
    • The following three digits represent the tire's width in millimeters.
    • Then, you'll see the slash, followed by two numbers referring to your tire's aspect ratio. The tire's aspect ratio is determined by dividing its height by its width, both measured from the rim.
    • Next, you'll see the letter R, which refers to the tire being radial. This is pretty much the only type of tire that's on regular cars.
    • Then you'll have the last numbers of the tire size, which represent the diameter of the wheel or rim measured in inches.
결론
And there you have it, now you can easily understand what your tire size means.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Chaya Milchtein
회원 가입일: 07/06/23
1,057 평판
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 21
전체 시간: 326
