주요 콘텐츠로 건너뛰기
How to Repair Scratched Eyeglass Lenses
Andrew Rose
Andrew Rose2 다른 기여자
최종 수정일 July 24, 2022
5 - 10 분
쉬움
Scratches in eyeglass lenses can make them difficult to see through. Fortunately, scratches can be fixed to make your glasses look just like new. Keep your glasses clear and free of blemishes in these few easy steps.
  1. How to Repair Scratched Eyeglass Lenses, How to Repair Scratched Eyeglass Lenses: 1 단계, 이미지 3개 중 1개 How to Repair Scratched Eyeglass Lenses, How to Repair Scratched Eyeglass Lenses: 1 단계, 이미지 3개 중 2개 How to Repair Scratched Eyeglass Lenses, How to Repair Scratched Eyeglass Lenses: 1 단계, 이미지 3개 중 3개
    • Place the eyeglasses, wax, and cloth on a flat surface.
  2. How to Repair Scratched Eyeglass Lenses: 2 단계, 이미지 2개 중 1개 How to Repair Scratched Eyeglass Lenses: 2 단계, 이미지 2개 중 2개
    • Remove any dirt or debris stuck to the lenses with a soft cleaning cloth.
    • Clean glasses gently; using excessive force can grind dirt into lenses and cause more scratches.
  3. How to Repair Scratched Eyeglass Lenses: 3 단계, 이미지 3개 중 1개 How to Repair Scratched Eyeglass Lenses: 3 단계, 이미지 3개 중 2개 How to Repair Scratched Eyeglass Lenses: 3 단계, 이미지 3개 중 3개
    • Dab some vehicle wax on the scratched area of the lens.
  4. How to Repair Scratched Eyeglass Lenses: 4 단계, 이미지 3개 중 1개 How to Repair Scratched Eyeglass Lenses: 4 단계, 이미지 3개 중 2개 How to Repair Scratched Eyeglass Lenses: 4 단계, 이미지 3개 중 3개
    • Buff wax into lens with a lint-free cloth using small, circular motions until the scratch is gone. This can take up to 5 minutes.
    • For especially deep scratches, you may need to re-apply wax and buff multiple times.
    • You may need multiple cloths, as the wax sticks to the cloth easily.
  5. How to Repair Scratched Eyeglass Lenses: 5 단계, 이미지 3개 중 1개 How to Repair Scratched Eyeglass Lenses: 5 단계, 이미지 3개 중 2개 How to Repair Scratched Eyeglass Lenses: 5 단계, 이미지 3개 중 3개
    • Using lukewarm water, rinse off glasses for 10-15 seconds to remove any additional wax.
    • To dry off glasses and remove any remaining wax on the lenses, wipe them off using a clean cloth.
결론
For particularly deep or persistent scratches, repeat these steps until the scratch is repaired.
다른 56명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Andrew Rose
회원 가입일: 04/09/15
2,163 평판
안내서 1개를 작성함
Cal Poly, Team 30-5, Green Spring 2015 Cal Poly, Team 30-5, Green Spring 2015 회원
CPSU-GREEN-S15S30G5
5 회원들
안내서 32개를 작성함
댓글 24개
thank you, i have a scratched lens and will try this. cheers.
amackay5 - 답글
Stupid is as stupid does! Think about it. A scratch is a certain width, when you polish it you are just grinding off the edges of the scratch and actually making it wider. So unless you are capable of removing all the surrounding material to the depth of the deepest part of the scratch AND maintaining the profile to within a very very small tolerance then this just WILL NOT work. Filling the scratch with wax cannot work either as wax does not have the same refractive index as the lens material. Conclusion: take care of your glasses and if you are careless enough to damage them it's your own fault, accept responsibility and replace them.
abscomm - 답글
This sounds like "I've not tried this but I've thought about it for a few minutes and this is what I think will happen". Very short on evidence.
steve -
Wow!!! Just couldn’t help yourself could you. Perhaps you’ve heard “If you can’t say something nice say nothing at all”! Grow up without doing it at someone elses expense.
Yaya -
Obviously, this person has never made a mistake and is absolutely perfect in every way.
Stuart Conner -
댓글 쓰기
조회 통계:
지난 24시간: 30
지난 7일: 223
지난 30일: 968
전체 시간: 245,922
