주요 콘텐츠로 건너뛰기
How to Repair a Loose Rear Bicycle Wheel
Lily Suggs
Lily Suggs3 다른 기여자
최종 수정일 May 8, 2023
20 - 40 분
쉬움
If you're an avid cyclist or even a casual rider, you may have experienced a loose rear bicycle wheel at some point. Riding with a wobbly or unstable wheel can be dangerous and potentially cause damage to your bike or even result in an accident. But don't worry, repairing a loose rear bicycle wheel is a relatively simple process that can be done with a few basic tools and some patience.
In this guide, we'll go over the step-by-step process for repairing a loose rear bicycle wheel. We'll cover how to loosen the rear axle, remove the wheel, assess the damage, properly set the wheel back into the dropout, and check for alignment issues. By following these steps, you'll be able to fix a loose rear bicycle wheel and get back on the road safely in no time.
So, let's get started with our guide on how to repair a loose rear bicycle wheel.
  1. How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: 1 단계, 이미지 3개 중 1개 How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: 1 단계, 이미지 3개 중 2개 How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: 1 단계, 이미지 3개 중 3개
    • Loosen the rear axle.
    • Turn the bike around, and loosen the brake arm.
  2. How to Repair a Loose Rear Bicycle Wheel: 2 단계, 이미지 2개 중 1개 How to Repair a Loose Rear Bicycle Wheel: 2 단계, 이미지 2개 중 2개
    • Take the chain off the gear and take out the wheel.
  3. How to Repair a Loose Rear Bicycle Wheel: 3 단계, 이미지 2개 중 1개 How to Repair a Loose Rear Bicycle Wheel: 3 단계, 이미지 2개 중 2개
    • Assess damage of the dropout and wheel.
  4. How to Repair a Loose Rear Bicycle Wheel: 4 단계, 이미지 2개 중 1개 How to Repair a Loose Rear Bicycle Wheel: 4 단계, 이미지 2개 중 2개
    • Properly set the wheel back into dropout and put the chain back on the gear.
  5. How to Repair a Loose Rear Bicycle Wheel: 5 단계, 이미지 2개 중 1개 How to Repair a Loose Rear Bicycle Wheel: 5 단계, 이미지 2개 중 2개
    • Pull on the wheel so that the chain is tight, while tightening the rear axle just enough to hold it in place.
  6. How to Repair a Loose Rear Bicycle Wheel: 6 단계, 이미지 3개 중 1개 How to Repair a Loose Rear Bicycle Wheel: 6 단계, 이미지 3개 중 2개 How to Repair a Loose Rear Bicycle Wheel: 6 단계, 이미지 3개 중 3개
    • Check for misalignment or frame rubbing by pedaling without resistance.
  7. How to Repair a Loose Rear Bicycle Wheel: 7 단계, 이미지 3개 중 1개 How to Repair a Loose Rear Bicycle Wheel: 7 단계, 이미지 3개 중 2개 How to Repair a Loose Rear Bicycle Wheel: 7 단계, 이미지 3개 중 3개
    • Fully tighten the axle.
    • Turn the bike around.
    • Reattach the brake arm.
결론
작성자
3다른 기여자 명과 함께
Lily Suggs
회원 가입일: 01/31/23
145 평판
안내서 1개를 작성함
UC Davis, Team 4-8, Andersen Winter 2023 UC Davis, Team 4-8, Andersen Winter 2023 회원
UCD-ANDERSEN-W23S4G8
3 회원들
안내서 1개 작성
댓글 한 개
Axle alignment is crooked, which can cause wobbling. Loosen the axle nuts or quick-release skewer, align the wheel, and tighten it securely.
Bruno John - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 28
전체 시간: 1,025
